Emission Problems!!
Old Jul 25, 2007 | 04:38 PM
Intense's Avatar
Default Which Cats!?
I am getting headers but it has to pass CA emissions. I am getting long tubes(dnt care about visual) but which cats should i go with?
I will be getting Pacestter Long Tubes. The reason I am asking is because of the prie difference between the two.
MagnaFlow or Pacestter Cats?
Thanks,
Taylor
Old Jul 25, 2007 | 05:04 PM
93redBIRDman's Avatar
honestly, stock cats off the for sale section. You won't be able to pass with any "high flow" cats in Ca... (from what I've read and heard, no first hand experience)
Old Jul 25, 2007 | 06:04 PM
Intense's Avatar
So stock cats will work? It wont pass the visual but it needs to pass other wise.
Old Jul 25, 2007 | 06:06 PM
joecar's Avatar
Stock cats won't fit on the header collectors (the stock cats have pipe with triangle flange attached, won't fit on collectors).
Have you already smogged...?
Old Jul 25, 2007 | 06:07 PM
Intense's Avatar
Nope... I have like another year and a half before i am due again.
Old Jul 25, 2007 | 06:09 PM
joecar's Avatar
I'm smogging next month, so it's going to be "interesting"...
Old Jul 25, 2007 | 06:10 PM
Intense's Avatar
I mean will it pass other than the visual with Hi flow or Pacesetter cats?
Old Jul 25, 2007 | 06:11 PM
joecar's Avatar
It will pass the sniffer test with either cat, provided you're not running rich...
sometimes a tune is needed after installing headers.
 Michael S. Palmer
Old Jul 25, 2007 | 06:14 PM
Intense's Avatar
Ok thanks It was over $100 price difference between them. Anyone ever used Pacesetter Cat?
Old Jul 25, 2007 | 06:17 PM
Just relaying back to you what I've read everywhere, aftermarket high flow cats will not pass the sniffer.
But hey you can take the chance if you want, but I wouldnt want to spend all that money if there's a good risk that it won't pass. Just my .02
Old Jul 25, 2007 | 06:20 PM
joecar's Avatar
They will fail visual inspection (as will the headers).
Old Jul 25, 2007 | 06:35 PM
vaticano's Avatar
SLP high flow cats on hooker headers, on a H/C car. I passed last year, but they had to run it twice. I wasnt finished tuning either, so i'm sure that caused the problem.
Old Jul 25, 2007 | 06:37 PM
ls1_doc's Avatar
I would use the magnaflow/carsound cats. Which was more expensive ?
Old Jul 25, 2007 | 07:37 PM
Intense's Avatar
I can get the Pacesetter ones for $125 each the Magnaflows are $275ish. Pacesetter says 50 state legal and they will pass.
I dont know which one will pass.
Visual I dont care about but it needs to pass the sniffer.
Old Jul 25, 2007 | 07:42 PM
2002_Z28_Six_Speed's Avatar
So are they leanient on the visual stuff as long as you pass the smog test?
Old Jul 25, 2007 | 07:43 PM
Intense's Avatar
Ya and the place that I will take it owns a Camaro lol.
He said I dont care if you have headers but it needs to pass the sniffer.
Old Jul 25, 2007 | 10:09 PM
GOaT Cheese's Avatar
It will still fail, the I/M monitors won't run with the LT's and goofy cats. As soon as your guy plugs into the DLC with his IM240, the state will be onto you. I F-ing hate Cali..
Old Jul 26, 2007 | 01:08 AM
I think you can still get around it.
I don't have emissions in my state but I bet you can talk to the right tuner or someone on the boards here in the tuning section.
I think he means that since the 02 is farther away it will try to make it too rich. With tuning software you could set the computer to trick it and program it leaner just for the test.
Or perhaps have it tuned and disable the trim cells so it can't change the AFR.
In fact, joecar might know. hehe
Old Jul 26, 2007 | 06:58 AM
Formulated's Avatar
Aftermarket cats are certainly capable of passing the sniffer. A friend of mine with an untuned '88 L98 car (cam / heads / intake / etc...) and a dynomax cat passed just fine. I know a lot of the import guys are passing with carsound (magnaflow) cats as well. The thing to keep in mind is that the aftermarket cats won't last as long, so after a few years you may have to replace them. But, with a good tune (the most important part) you can pass with high flow cats.
Old Jul 26, 2007 | 12:58 PM
Intense's Avatar
Are you sure but from reading above it is hard to agree with that.
