threaded rod for pulley install?
Old Jul 25, 2007 | 11:50 PM
spy2520's Avatar
Default threaded rod for pulley install?
anybody got the specs on the all-thread rod and nut used to install an underdrive pulley? been trying to search but for some reason its being an ***.
Old Jul 26, 2007 | 12:55 AM
bsf's Avatar
bsf
M16 x 2.0 pitch x ~10.5" (my condensor was out of the car - ymmv)
4 nuts
~3.25" washer stack (or smaller stack with bearing doo-hickey)
Old Jul 26, 2007 | 01:16 AM
spy2520's Avatar
4 nuts? damn, and some hella-thick washers? seems manageable i guess.
why 4 nuts?
and the stock bolt is around 5" correct? i need enough length on the rod to be short enough to get a socket wrench on there, but long enough to thread a nut on while the pulley isnt all the way seated i guess.
Old Jul 26, 2007 | 02:33 AM
bsf's Avatar
bsf
I do not fully understand the physics behind it, but this is how I did it.
  1. Thread rod in all the way.
  2. Start the pulley by hand
  3. Put washer stack on,
  4. Run nut up to washer stack.
  5. Put 2 nuts back-to-back on end of rod and lock them together.
  6. Keep the rod from turning using the back-to-back nuts while driving the washers and pully forward using the other nut.
  7. The 4th nut is just to hold the washer stack on the rod when you are done.
If you have a thrust bearing, use that in place of some of the washers. Otherwise, use some oil.
Old Jul 26, 2007 | 03:04 AM
spy2520's Avatar
makes perfect sense. use two nuts as jam nuts. genius...
Old Jul 26, 2007 | 09:12 AM
spy2520's Avatar
should i get a new GM bolt or can i just use any high grade bolt of the same size? is the TTY feature really important?
Old Jul 26, 2007 | 10:34 AM
bsf's Avatar
bsf
Do not reuse stock bolt. I do not use TTY. I replace such bolts with reusable ARP fasteners.
Old Jul 26, 2007 | 10:55 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I'd recommend buying the tool HAWK618 sells on here...it is a very nice quality piece, and used a thrust bearing so you won't have any binding issues while driving the pulley down.
Also, torque to yield bolts are not designed to be used more than once...after something has yielded, technically, it has failed. Either buy a new one from GM, or spring for the ARP bolt, which is more, but is a very, very nice bolt.
Old Jul 26, 2007 | 11:57 AM
99blancoSS's Avatar
I rent out a cam swap tool package that includes HAWKS's tool.
Also the ARP will require a 27mm 12pt socket.
Old Jul 26, 2007 | 01:13 PM
spy2520's Avatar
i was asking whether i should get a GM bolt or go to the hardware store and get one.
and it looks like i'll be ordering the tool since out of 3 different hardware stores i cant find metric all-thread and i could only find M16 x 2.0 x 90 bolts. the crank bolt size should be M16 x 2.0 x 103 according to GM.
i'm cant believe i cant find this stuff anywhere.
Old Jul 26, 2007 | 01:22 PM
99blancoSS's Avatar
Its not common stuff. You can find it online at bolt depot but there are a lot of metric struff that isnt common in stores. I fight it all the time. Something like an 8m 1.25 x45mm cant find in stores. Its not big or small but 45mm is not common they are either 40mm or 50mm. It can be a PIA
Old Jul 26, 2007 | 01:48 PM
bczee's Avatar
Grease them washers to keep them from binding and make it easier for all to turn.
Old Jul 26, 2007 | 02:07 PM
davered00ss's Avatar
Moderator
Check in the tools forum. There is a guy making tools for pully install/removal for $30 or $40.
Old Jul 26, 2007 | 02:12 PM
spy2520's Avatar
yeah i just saw it, $44.
Old Jul 26, 2007 | 02:18 PM
MeentSS02's Avatar
And worth every penny. I'll never install another pulley without it.
Old Jul 26, 2007 | 06:51 PM
spy2520's Avatar
seems worth it even if i only use it once, considering i pissed out that much gas just looking for the **** today.
Old Jul 26, 2007 | 09:24 PM
bsf's Avatar
bsf
I have enough left to make up 2 or 3 more tools as I could only by it in 1m lengths. PM me if you are interested in a chunk of it.
Old Jul 27, 2007 | 01:02 AM
boondiggys's Avatar
i thought it was a 1-13/16" socket
Old Jul 27, 2007 | 02:36 AM
bsf's Avatar
bsf
1 1/16 = ~27mm
Old Jul 27, 2007 | 12:45 PM
boondiggys's Avatar
thats right. i just had that number in my head to remember to bring the broken socket back for warranty.
