Exhaust pipe question
Old Jul 26, 2007 | 03:00 PM
ravensfan's Avatar
Default Exhaust pipe question
Im installing my tsp duals, and I can not get the y-pipe off the drivers side header. Im curious if lining up the pipes and securing them with the sleeve clamps that come with the tsp system will be a problem.
Old Jul 26, 2007 | 03:12 PM
bww3588's Avatar
not quite sure what your qusetion is, try twisting on the y-pipe to get it moving around and pull it off. what i did when i put my TSP duals on was put anti-seize on all the joints, that way they come off easily.
Old Jul 26, 2007 | 07:57 PM
Sluggish's Avatar
Are there cuts in the to let the female part expand. It there is take a small hammer and beat around the inside to flare it out more. If this isn't cuts in the end.....make some.
Old Jul 27, 2007 | 07:36 AM
Powerstick's Avatar
Are you asking if the thin Torca clamp will work as a good butt-joint connection? Definitely NO. Use an ID/ID connector & a pair of AccuSeal clamps. Tell me what pipe diameter you are working with & I can give you part #'s.
Old Jul 27, 2007 | 09:41 AM
ravensfan's Avatar
Got the pipe off the header by cutting through the pipe itself and prying it off with some tools. Definately not something I wanna do again.
