BeCool Radiator install
We had to trim part of the lower frame support to get it to sit in the stock lower rubber mounts properly. You have to trim a little of the fan shroud to clear the WP pulley, worse if you have an Meziere Eletric pump. These mods did make it fit better than I have seen in other cars though. We also had to remove a little bit of upper rad hose to make the bend now that the rad face is closer to the block. I highly recommend changing your clamps on the rad hoses too. The stockers blew off my car, the first time pressurized. The oulet on the B Cool does not have as good a barb on it as the stock rad and when combined with the spring clamp it fails.
Hope that helps a little.
I have no more than about an eighth of an inch clearance, but that should be enough to get the job done since I have poly motor mounts. Time will tell, and I'll have to put it through its paces to make sure, but I'm pretty confident it'll end up working.
I think the installers that say they fit install them while the motor is out or remove the AC pipes and hoses and also the water pump (I have a Meziere) and don't have the problems when trying to force the radiator down while holding the AC hoses and other stuff out of the way while the motor is in - same for the ATI fan and shroud.
After finally getting it in on the last attempt we discovered the pin to hold it in place is centered on the bottom of the radiator and it would not drop into hole (the pin should have been welded on the back half of the bottom of the radiator instead of the dead center). Rather than enlarging the hole at bottom of radiator mount we cut the pin off.
We had to bend the ATI panel that pulls the radiator forward and holds it in place. It would not stay without cutting holes in the mount - it would pop off.
Be careful too when hanging the ATI shroud. Bolts on the inside of the ATI shroud got into one tube on the brand new $500 BeCool - so we yanked it a 7th time to have the tube welded.
Temporarily I installed a bigger 97 manual version ($125 new) radiator but it still gets borderline hot with the AC on (runs 230-240).
I will install the BeCool again, but when the motor is pulled to install the 408. Then will have plenty of room to make sure everythings fits correctly with room to work and not destroy things during the install. And I'm going back to a regular water pump. The Meziere isn't helping at all with my overheating.
I recall there is something else different too - drain plug is moved to the opposite side on driver side instead of passenger side presenting more problems with a Charger installed?
