Not getting full throttle!!!!
Old Jul 27, 2007 | 07:38 PM
juicedls1's Avatar
Default Not getting full throttle!!!!
Alright i just installed my 408 with a Victor Jr, Elbow by aaron larson, and a Holley 90mm tb, u have to drill holes in the elbow to mount the throttle bracket, my problem is i got the bracket as far back as possible till its just about to pull the throttle lever, then i mounted it, but im only getting 3/4 throttle, if i move it back any further itll move the lever and idle the car up! Is there any adjustments anywhere for the cable? Or do i have to put the stock throttle shaft on? Thanks n Advance!!!!
Old Jul 27, 2007 | 09:52 PM
juicedls1's Avatar
Anyone????
Old Jul 28, 2007 | 11:32 AM
DirtyJohn's Avatar
3/4 throttle difference is wicked. almost makes me think you have the cable in the wrong hole in the Throttle body, I did that once.
Also check out this area...
You can adjust the slack there too, but not 3/4 worth.
Old Jul 29, 2007 | 01:04 AM
juicedls1's Avatar
Cool man thanks, i have got 3/4 throttle (81%) just missing the other 19% so i can adjust it out there.
Thanks
Robby
