Intake tube is a heat soak
Old Jul 28, 2007 | 06:56 PM
04ctsvfl's Avatar
Default Intake tube is a heat soak
I was wodnering if you all had any suggestions for minimizing the amounnt of heat my intake tube is absorbing. I was thinking duct tape? header tape traps the heat from leaving pipes....so I dont think its applicable hear, as Im trying to repel heat. Please let me know if you have any ideas.
Old Jul 28, 2007 | 07:52 PM
98Camarod's Avatar
what are you talking about?
Old Jul 28, 2007 | 08:43 PM
WS6NIGHTMARE's Avatar
Well Im going to assume your intake is the stock rubber one, so its not getting any heat soak. *If* you wanted to wrap it in header wrap that would achieve the effect you are thinking you need. Its a thermal barrier, keeps whats in, in. And what out, out. But its pointless.
Old Jul 28, 2007 | 09:14 PM
04ctsvfl's Avatar
no, I have a 4 inch aluminum intake tube, and yes it does absorb alot of heat. Header wrap will achieve this? Even if I can lower it by a few degrees ill be happy.
Old Jul 28, 2007 | 09:15 PM
04ctsvfl's Avatar
http://cadillacfaq.com/faq/answers/img/sv/st-caik2.jpg
Old Jul 28, 2007 | 09:17 PM
Well what your trying to do is keep the heat out, so yes, header wrap will work just fine.
Old Jul 28, 2007 | 09:48 PM
04ctsvfl's Avatar
Thankyou.
Old Jul 29, 2007 | 10:12 AM
staringback05's Avatar
are you seeing loss through it?....my problem with heat soak is that unless you sit in the staging lane at the track forever, or roll race at 5 mph...its not a real issue....when your cars moving...its got alot of air moving over and moving the heat off anyways....this is why you car moves from 180-210 from driving to sitting, anywhere in that range...(hook it up to live and watch it)
