cracked cat
Old Jul 29, 2007 | 04:22 PM
DevilDougWS6's Avatar
Default cracked cat
i went to meineke to check out my exhaust leak and get a cut-out put on...they found that the left bank cat has a hairline crack about 2 inches long at the top, near the flange. but here is the dillema, buy an OEM cat from GM for 400 dollars, or 2 high flow cats from slp for 350? im not sure but i need the whole cat with the pipe and the flanges, not sure what to do because i dont want to spend alot of money. they said they would replace both cats for 150 bucks labor....what should i do?
Old Jul 29, 2007 | 04:45 PM
RevGTO's Avatar
Pontiacerator
It should be under warranty. Did you talk to a dealership service department?
Old Jul 29, 2007 | 04:58 PM
bww3588's Avatar
get some mangnaflow high flow cats for $35 a peice.
Old Jul 29, 2007 | 05:56 PM
no the dealership warranty is out...i found "scrap" ones on ebay for 10 bucks.
Old Jul 29, 2007 | 06:15 PM
PureWS6's Avatar
The cats on your car should be warranteed for 8-10 years
Old Jul 29, 2007 | 06:57 PM
sroach20's Avatar
why not pull it and weld it up?
