high mileage maintenance
Old Jul 29, 2007 | 08:53 PM
NxLS1496's Avatar
Default high mileage maintenance
ok, the mileage on my camaro is getting up there. its a 98 auto z28 with t/tops and its at about 89000 miles. obviously changing the oil is going to keep her alive longer but seeing how as im about to hit 90k miles what else would you guys do? i changed the fuel filter at about 80k miles, i should probably change the plugs and wires right? i bought her with 68k on the clock and im not sure what the previous owner did as far as maintenance. car runs great, but i think my transmission might be on its way out. it shifts kind of hard and last week when i floored it from a 60 roll it downshifted fine but when the time came to shift it bounced the rev limiter. first time its done that. so let me know what fluids i should change, maybe i should do a seafoam? let me know, thanks guys.
Old Jul 29, 2007 | 09:00 PM
A-RoN'sZ's Avatar
My 98 just clicked over on 94k and I've done the complete Seafoam treatment (changed the oil 150 miles afterwards), changed the fuel filter (made it run smoother and the old one was shot), and I'm about to change the plugs and rear end fluid.
Old Jul 29, 2007 | 09:26 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Here ya go for seafoam: https://ls1tech.com/forums/general-maintenance-repairs/605412-seafoam-startup-idle-videos.html
And: https://ls1tech.com/forums/general-maintenance-repairs/534376-how-seafoam-your-car.html
Old Jul 29, 2007 | 10:08 PM
SUTTERERMAN85's Avatar
my stock motor lived till 149K and thats because i took it out againts its will. nothing wrong with it other than a little smoke on a high rpm decel in gear. keep the oil changed on a regular basis and do the little maintenance tunes like orange appeal sent you links to. i was HARD on my motor too
Old Jul 29, 2007 | 10:14 PM
Phoenix 5.7's Avatar
flush trans fluid/filter, rear end fluid, flush coolant system
Old Jul 29, 2007 | 10:41 PM
bene's Avatar
Trunion King
Time to change your tranny fluid, and maybe your rear fluid also.
Old Jul 29, 2007 | 10:47 PM
PureWS6's Avatar
plugs/wires/tranny flush with filter/drain and refill rear end/sea foam
I changed my stock plugs at 36k...and they were already wasted...so I would recommend getting your stockers out of there
Old Jul 29, 2007 | 10:54 PM
bene's Avatar
Trunion King
Do your brakes! Brake fluid, pads, and if your stock rotors are warp, change them.
Old Jul 29, 2007 | 11:35 PM
NxLS1496's Avatar
anyone have a write up on how to change all your fluids and brake pads?
thanks for the other help also, will do the seafoam next weekend.
Old Jul 30, 2007 | 04:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
There was a write up on the blinker fluid change.
Old Jul 30, 2007 | 06:11 AM
Fb0dy0nly's Avatar
damn, I missed that one, who has a link?
Old Jul 30, 2007 | 06:35 AM
CavPat's Avatar
I changed my motor at 93,000 miles. ...because I bent a connecting rod (oops).
Old Aug 4, 2007 | 01:54 PM
NxLS1496's Avatar
looks like ill be holding up on other maintenance, my a/c compressor just took a ****. there goes $900.
Old Aug 4, 2007 | 02:15 PM
Soul TKR's Avatar
Old Aug 4, 2007 | 02:20 PM
Soul TKR's Avatar
Just turned over 115k on mine... It's running good cept for a suspicious clogged cat... which will be fixed soon hopefully...
I always changed the oil every 3k miles using Mobil 1 10w30 for a higher mileage car... recently i've started to use the "Extended Performance" line for Mobil 1... Got my rear fluids changed a couple months ago, everything looked real clean... swapped plugs at about 85k miles. Done Seafoam 2 or 3 times. Just flushed the coolant system with my radiator swap... When I blew my tranny I had it rebuilt, I'm guessing that means new fluids...
