check engine light after ported TB install
Old Jul 31, 2007 | 06:07 PM
darkside98's Avatar
Default check engine light after ported TB install
ok so i ported my throttle body and now my check engine light is on...anyone else have this problem
Old Jul 31, 2007 | 06:14 PM
MUSTANGBRKR02's Avatar
did you remove the sensors? if not you probably got shavings in there
Old Jul 31, 2007 | 06:38 PM
Bo White's Avatar
What is the code?
Old Jul 31, 2007 | 06:39 PM
darkside98's Avatar
ok i'll check that
Old Jul 31, 2007 | 08:00 PM
Shinji43's Avatar
When I swapped mine for the BBK 85mm TB I had a light for a while (about 50-75mi) then it just cleared itself out, I didnt have a chance to check what codes it was, I figured just the drastic change in air difference threw it off enough ti trip it till it relearned and adjusted itself to the new TB.
Old Jul 31, 2007 | 08:05 PM
SpdFrk1990's Avatar
Did you unhook the battery? Also if you swapped the iac and tps to another tb did you make sure the o-ring was on the iac?
Old Jul 31, 2007 | 09:17 PM
StealthLSJuan's Avatar
I got a CEL when I had mine done, it was because the TPS was a hair off and wasnt getting the right voltage.
Old Jul 31, 2007 | 09:35 PM
darkside98's Avatar
checked the code it was P0172 & P0175 to rich on both banks, i talked to a tuner here in town and he said that the computer was just trying to OVER compensate for the additional air the engine is getting now
