LS6 intake modification
https://ls1tech.com/forums/generation-iii-external-engine/618070-finally-did-ls6-intake-swap.html
Also, I think there is a TSB out that prescribes building a litte "dam" around the knock sensor hole plugs/boots with red RTV to keep water out. I diid not do that, but I did put some grease on the plug/boot to make a better seal with the valley cover.
