Can't get crank pulley off
Old Aug 5, 2007 | 09:46 AM
1B@DZ's Avatar
Default Can't get crank pulley off
Hey guys,
Need some help here. I can't get the crank pulley off my 02 Z06. Are there any secrets to this? any tips? I'm about fed up with it. I'm using the 3 arm jaw puller.
I was thinking to cut the outside part off and grab the middle with the jaws. I have a new UD Pulley, so i don't need the stocker.
Any ideas guys.
Josh
Old Aug 5, 2007 | 09:52 AM
Amoretti's Avatar
I'm not sure if the tools are the same, but I had major problems pulling off my power steering pulley.
If its a pressed on pulley, try giving more slack on the threads. I know that doesn't sound like it makes sense, but I had the puller tightened up too tight against the pulley, and didn't have enough thread to pull it out. Didn't realize it till hours later.
Also, make sure you're using a breaker bar. It takes a lot to break those free.
Old Aug 5, 2007 | 10:00 AM
davered00ss's Avatar
Moderator
# jaw puller. If it's giving you a hard time try some heat.
Old Aug 5, 2007 | 10:18 AM
1B@DZ's Avatar
thanks for the advice guys. I went ahead and left it for now before I got pissed and broke something else. I'm using Tim's tool to do the valvesprings right now. It's working perfectly, which is helping my attitude and increasing my optimism.
Thanks, I will try the breaker bar tip first b/c I'm pretty sure I got to that point but didn't want to mess the tool. Now I don't care, I just want the pulley off.
I'll try heat if that doesn't work.
Thanks again guys,
Josh
Old Aug 5, 2007 | 11:39 AM
kyemt's Avatar
Default pully
yea im kinda in teh same bolt on my gto, i cant get the bolt to turn at all, even with a good impact, what do i need to do apply some heat to the bolt wd 40 big breaker bar , what ?
Old Aug 5, 2007 | 06:12 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I had a hell of a time trying to pull my old Powerbond UD pulley off my crank with a 3-jaw puller. I damn near ended up breaking it, and still couldn't get it off. I had to use a different style puller (the late model Chrysler harmonic balancer puller), but that wouldn't fit on a stock diameter balancer. I think the key is making sure the shaft of the 3-jaw puller is centered exactly in the crank.
Old Aug 5, 2007 | 07:28 PM
1B@DZ's Avatar
I finally got it out. It's a matter of playing with the many settings that stupid thing has. We finally managed to get 2 jaws on the center section and the last one on the outer section from inside. That jaw was bolted right to the black part of the tool.
it was a pain, but finally came out. The bolt is royally F*cked though. It's stripped out in 2 places. What a cheap piece of crap.
Thanks for the help guys.
Josh
Old Aug 5, 2007 | 08:22 PM
Amoretti's Avatar
Glad to hear you got it out. I know how much of a bitch pulleys and their tools can be.
Old Aug 5, 2007 | 09:24 PM
kyemt's Avatar
Default bolt
i just want to get the bolt to break free any ideas?
Old Aug 6, 2007 | 08:18 AM
1B@DZ's Avatar
What Trans do you have? If you have a manual then pull the parking brake and put it into 4th gear. Remove the plugs (didn't think it mattered but it did). Get a 24mm socket (I think) and use a 2'-3' breaker bar on that bisch. It should rotate just a little then start to come loose. It will take a turn or two to break loose to hand tight.
Josh
Old Aug 6, 2007 | 08:46 AM
kyemt's Avatar
Default tranny
i have a m6 and your right it is a 24mm socket ok ill try that this week when i get off work im hoping that will do it thanks
Old Aug 6, 2007 | 09:26 AM
1B@DZ's Avatar
No Problem, PM me if you have problems.
Josh
Old Aug 6, 2007 | 12:46 PM
98Camarod's Avatar
I used the three arm jaw puller, but you cannot do it as pictured in ls1howto.com. I bent two rods, I switched it so it was as short as it could get and it came right off.
