Victor Jr EFI vs. Fast 90
Old 08-31-2007, 01:31 PM
  #141
Super Hulk Smash
JakeFusion's Avatar
Has anybody tested the Super Victor? It's a little taller, but with much larger plenums than the Vic Jr. I imagine it will flow excellent but may be geared toward the upper RPMs, say 6500-8000.
Old 08-31-2007, 09:54 PM
  #142
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Wow, I just read all of this to be greatly disapointed. I'm in the same situation now as to trying to decide on which intake to pick for my new engine. I guess it's still up in the air.
Old 09-24-2007, 08:19 PM
  #143
SLowETz's Avatar
So.... did anyone ever get started on a back to back port/flow/dyno/track comparason?
Old 01-15-2008, 10:31 PM
  #144
Robert56's Avatar
Lots of talk, but still no real data. Anybody? I have a vic Jr getting plumb for Dry DP, will it work, I think so. Spraying and blowing plastic intakes apart was part of my choice, but seems the jury is still out for some. Tony or Ron, any insight on spraying and the Vic jr? By the way, tq loss is certainly not an issue in any way shape or form, down low, lol.
Robert
Old 05-04-2008, 02:28 PM
  #145
Moderator
LIL SS's Avatar
FYI.. I have some dyno time owed to me (work trade out for doing some local work). I was planing on testing:
Stock LS6 with ported TB (Currently on the truck)
Stock Fast 90/90
Stock unported Vic JR with ported stock
Stock unported Vic JR with 90
Stock unported Vic JR with 105
Stock unported Super Vic with ported stock
Stock unported Super Vic with 90
Stock unported Super Vic with 105
Test bed is a forged 347ci motor
ABS heads
--------- In-------EX
0.200----149-----112
0.300----208-----169
0.400----257-----201
0.450----276-----211
0.500----288-----219
0.550----296-----222
0.600----306-----226
Trex
4L80E w/ fuddle 4,400 verter
12 bolt with 3.73's
30x13.50 ET Street
Current dyno with LS6/Stock ported:
I need a Super Vic and if someone like Tony wants to throw a ported 90/90 in to the mix, I'll be glad to send it back when done. I have my motor apart right now waiting on head gaskets and studs but they should be here I would think by next week. I could probably slate the time to do the testing towards the end of the month.
All testing on the Vic's JR and Super will be with out a 90* elbow. They will be plumed straight up like a smoke stack as that's how I would run it on my truck.
Old 05-04-2008, 05:14 PM
  #146
sciff5's Avatar
The carb intake is really supposed to be used with a 4bbl carb style throttle body for best results, any way you could test it with the 4bbl?
Old 05-04-2008, 07:20 PM
  #147
Moderator
LIL SS's Avatar
If someone wants to send me one.. Again, it will not be tested with an elbow on the standard style TB's..
Old 05-12-2008, 05:35 PM
  #148
Black98Z28's Avatar
I was considering the Vic JR but not any more, Ill stick with the planned FAST 90.
Old 05-12-2008, 08:10 PM
  #149
Robert56's Avatar
I won't be giving up so easy. I believe it's just a matter of people getting some experience tuning the single plane as it pertains to the EFI/LSx platform. Many big dogs (majority of nitrous users) are already running the single planes for ultimate power. That's what the manifold is designed towards, the drag racers whom will be in the upper ranges of the rpm band for the most part, and the couple HP you loose down low really matters not, it's all about WOT performance. One area I am working on is fine tuning with plenum volume. Wilson has numerous carb spacers designed just for this, and currently have one of their 1¼" spacers. here's mine as it looks currently, DP Dry and Vic Jr with spacer installed and temp elbow.
Robert
Old 05-12-2008, 10:55 PM
  #150
GIGAPUNK's Avatar
For a plate system of course it makes sense. But for the rest of the world, loosing 20 ft lbs every where under 5800 rpm is a lot to overcome and more than a tuning issue.
Old 05-13-2008, 12:36 AM
  #151
Robert56's Avatar
With the limited data and inconclusive testing that's been done... The point is, most current tests have been done with cams designed for the front intlet, below the runners plenum, style intake, rather than a central intlet, plenum above the runners, intake. So until someone builds a motor around the single plain intake, then does a change to a fast intake and the tq loss is still there, it's still speculation at best (not the other way around as has been done currently). It's my opinon, based on years of running the carb style open plenum intakes, that we have yet to see all there is. But then again, maybe it's just a high rpm only intake? But, for street/strip, i think it will win out in the end. The dual plane intakes of past could never breath up top like a single plain and this may be the case with the LSx style stock intakes, better for crusing around town, but not the best street/strip intake. Time will tell, though.
Robert
Old 05-13-2008, 01:38 AM
  #152
LS1 Cobra's Avatar
The standard intake, the FAST and the Victor Jr are all single plane designs. Dual Plane refers to a design where each half of a 4 barrel carb would feed 4 cylinders. There was a divider in the plenium. They made better bottom end because effectively those 2 banks of 4 cylinders were exposed to a carburettor 1/2 the size of a single plane. They also had less turbulence caused by the reversion reversion pulse from the valve closing on the other cylinders.
The main difference between the design of the Victor and the FAST is the plenium is much larger on the FAST and the runners are longer.
Cheers
Michael
Old 05-13-2008, 08:31 AM
  #153
s346k's Avatar
there is no doubt that a single plane setup is capable of making more power. the problem is, you can't use a cam taylored to the crossover style intake and expect a huge gain. use a cam for the single plane carb style tb setup and we will see what we're looking for.
Old 05-13-2008, 08:05 PM
  #154
Robert56's Avatar
Cheers
Michael
Agreed, but the point is that a front entrance open plenum in not the same as a central entrance open plenum, air dynamics are totally different. A whole different ball game. That is why Wilson has the plenum spacers, this way you can tune your intake's plenum volume to match your RPM goals. The FAST will fall off at some point where as a conventional single plain can be tuned to go much further. Now we have the Super Vic for the biggest CI motors and the heads like 235/245s that can flow the numbers. So much out there for us these days, it's good to be rodding the LSx platform for sure.
I think the main difference between the FAST and Vic and Super along with the GM single plain, is the distribution, much more even with a central entrance style intake, just basic physics. Also, the LSx intakes have the plenum below the runners and the carb intakes have it above the runners and thus the different air dynamics. Don't get me wrong, the FAST from a good porter is hard to beat, but for some, the new single plains are the way to go and definitely have a great future.
Robert
Old 05-13-2008, 09:02 PM
  #155
LS1 Cobra's Avatar
I agree with you Robert, They will both behave quite differently with the very different shapes of the two manifolds affecting the way the air flows.
I must preface this by saying I'm no expert but I've thought a lot about the two designs.
The FAST and stock style manifolds have much longer intake runners which is proven to be better for low end performance. Shorter runners are better for top end. The volume of the plenum will have a big impact as it resonates at a particular RPM range. To my way of thinking a larger plenum resonates at a lower frequency therefore lower RPM.
The throttle body at the front of the manifold is a design compromise for hood clearance and ease of plumbing. I like the idea of a central throttle body for even airflow distribution. I guess it's not as critical now with the injectors right at the port but it used to be a major issue with carb manifold design. What i think will be a factor is the turbulence from one port affecting the flow of an adjacent port. Having a central throttle body has to be better in this regard as the flow to all ports should be more even.
Cheers
Old 05-14-2008, 12:43 AM
  #156
Robert56's Avatar
The only thing I disagree on is the plenum volume being increased will be directed at lower RPMs, not true, it's really more towards higher RPMs. Look at the tunnel rams and such, mucho plenum volume and pretty much dogs on the street, or at lower RPMs. though they can be made to work and I have run numerous dual quad tunnel rams on the street. The problem with the increase volume is we loose velocity at low speeds. meaning, the capacity capabilities of a high plenum volume intake will in fact slow way down at low RPMs and thus become a problem. however, it's not as big of a problem with EFI platforms as it is with carb platforms as one requires mechanical keys and the other can rely on electrical commands (PCM). So one can be tuned around this issue much easier than the other. I know I could explain this better, but it's getting late and going to bed, lol. I hope it will make some sense to someone. Oh yea, the pulsling does play a roll in all of this also, as you suggested, more later.
I agree on the hood clearance consideration being required in the design of the front inlet intakes. actually they did very well considering the design restraints.
Old 10-29-2008, 06:12 PM
  #157
Monte4ever's Avatar
I just sat here and read this whole post and no dyno results - DAMN. Was VH5150 right? Is that's why we have no results? I agree with s346k - you can not make a direct comparision using a cam designed for an LS1 or Fast intake. Get the valve timing right and I BET you'll have a completly different outcome.
Old 10-30-2008, 10:20 PM
  #158
GIGAPUNK's Avatar
I'm not buying it. How would you optimize a cam for the single plane? More duration to try and match the shorter runners for everything to come together a bit more up top? More overlap? Neither of those moves is going to help the bottom end.
Old 10-31-2008, 07:55 PM
  #159
Monte4ever's Avatar
I'm not a cam expert, but one thing that I do know is that most LS type manifolds utilize a cam that has a wide lobe separation angle (113-116) which works well for that manifold design, but when using an old school manifold (Victory Jr), I think your should use a cam that fits that design with a LSA of around 110-112 unless you're going FI or want to rev it to the moon. On the Victory Jr, just closing up the LSA will boost low end torque while still providing upper RPM HP. If I was to use the V. Jr, I would build it like I was building an old school SBC - as far as cam choices are concerned (if that makes any since). Now I'm not saying it will out perform the Fast, but I think it would perform a hell-of-a-lot better.
Old 11-01-2008, 10:05 AM
  #160
GIGAPUNK's Avatar
I think you're mostly correct. However, I believe that the wide LSAs that are rampent with the LS crowd have more to do with driveablility and emissions than performance. I think, with a decent exhaust, that the increased overlap from a tighter LSA would benefit both the victor and underplenum design equally. I guess I'm just reiterating that no cam swap is going to make the victor do something it wasn't designed to do (produce torque under 6500 rpm).
Quick Reply: Victor Jr EFI vs. Fast 90
