fast intake does not fit...problem solved
Old Aug 7, 2007 | 08:37 PM
trophystock's Avatar
Default fast intake does not fit...problem solved
I just got done setting a fast intake on my 99 C5. I have .037" milled heads. The intake would not sit down on the heads all they way. I found that the bottom of the intake was hitting the valley cover bolts. I swapped out the hex heads and installed 10 button head bolts, problem solved. Just thought i would give everybody a heads up if you didn't know that already.
CWB
Old Aug 7, 2007 | 09:15 PM
studderin's Avatar
directions ???
also the 90mm, the front coolent tube need a little down bending.
Old Aug 7, 2007 | 09:25 PM
bought it used so i had no directions, the front coolant tube was persuaded with a small rubber mallet.
Old Aug 7, 2007 | 09:52 PM
studderin's Avatar
cool
only go to 50in#s
tstock specs is alor for the 3piece design. fast says got to 50
