Hurst Roll Control Install (Thunder Kit) QUESTION!
Old May 22, 2003 | 10:24 AM
Mr. B's Avatar
Default Hurst Roll Control Install (Thunder Kit) QUESTION!
I have to splice into a ignition switched hot lead, which can be found under the fuse box and is a heavy wire, pink in color. One of my harnesses (under the upper fuse box) has many different pink wires, of varying guages.
Any advice as to which fusebox (upper or lower) and which pink lead (light or heavy guage) to use?
Thanks..
Old May 22, 2003 | 10:42 AM
BLKWS6's Avatar
Default Re: Hurst Roll Control Install (Thunder Kit) QUESTION!
I'm not exactly sure since i havent installed one, but if you just need an ignition wire to tap into, you could just use the one on the radio harness. thats the one recommended for the shift light installs.
just a thought....
