Which head sensor question...
Old Aug 12, 2007 | 03:17 PM
Halloran's Avatar
Default Which head sensor question...
Well I swapped my 853 stock heads with the new 243's and everything is going well. However in the mix of everything I can't remember if the driver or passenger side get's the sensor and which side gets the plug. I can't seem to find any wire that matches up the the sensor on either side of the heads.
Thanks
Old Aug 12, 2007 | 06:38 PM
Halloran's Avatar
Anyone at all?...
Old Aug 12, 2007 | 06:53 PM
98Camarod's Avatar
Driver side gets the sensor, right by where it plugs in at in the front. If i remember right it should have a little yellow rubber thing on it.
Old Aug 12, 2007 | 06:55 PM
2001NBMZ28's Avatar
It's my understanding the stock 241's are the same for either side and either can be used. ECT/connector should be on the drivers side just forward of the #1 cyl, so passenger side (by #8) has the plug.
