alternator
Old Aug 13, 2007 | 02:30 PM
stevensLS1's Avatar
Default alternator
i just bought a few alternator b.c whenever id turn my air on it would drop b.t 8-13 but driving was at 13 ( yellow area) and my lights flickered at idle. i changed it and now it sits b.t 8-13. what could be wrong?
Old Aug 16, 2007 | 06:12 AM
stevensLS1's Avatar
come guys help me out please... just had the battery charged so its still good. anyone???
Old Aug 16, 2007 | 06:54 PM
Starion's Avatar
Check all your terminals. The positive lead on mine was corroded bigtime and caused some low readings when the ac was on like yours. If everything is ok your battery still might be on its way out. Cheap rebuilt alternators aren't the best either. I've also heard the exciter wire on the alternator is a problem point as well, check to make sure it's in good condition and connected well.
Old Aug 16, 2007 | 10:05 PM
Dal1as's Avatar
Doublecheck the exciter wire connection on the top of the alternator.
If that's not it, get the new alternator tested.
Old Aug 17, 2007 | 07:04 AM
stevensLS1's Avatar
well thanks guys. ima take it to the dealer mechanic that i know quite well so ill se what he also says. btw its an ac delco alternator. i did accident arc it tho :-/ lol
Old Aug 18, 2007 | 01:11 PM
stevensLS1's Avatar
update. got the other alternator replaced with a new ac delco problem is still there. wires are ok. could there be a fuse??? please help me out.
Old Aug 21, 2007 | 11:11 PM
dgadson's Avatar
Have you done any work on your spark plugs/wires/coils recently?
Old Aug 22, 2007 | 04:00 AM
jtmiller92's Avatar
check your grounds
 Michael S. Palmer
Old Aug 22, 2007 | 04:13 PM
stevensLS1's Avatar
i got it fixed this weekend. it was that bullshit fuse in the wire that runs coming out of the alternator. very easy fix thanks tho guys
Old Aug 22, 2007 | 08:01 PM
sixvi6-camaro's Avatar
which wire the main power one or the exciter wire? where is this fuse at?
I have the same problem with car intermintantly.
Old Nov 10, 2007 | 11:54 PM
Bluebird5.0's Avatar
Hey, where exactly is this "fuse" in the wire? I've been having a hard time with the exciter wire and trying different connections to stop the lights from dimming but no matter what kind of connection I try they still flicker. Maybe it's this "fuse". Could you please tell me where to find it exactly?
Thanks,
Shawn
Old Nov 11, 2007 | 01:45 AM
atxz/28maro's Avatar
ya having very same problem, except i've been thorugh 6 alternator, they work for about 5 days usually, then blow...but ithin the last 2 days i've blow 3 alternators, i have no idea what to do
Old Nov 11, 2007 | 05:21 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Every once and while mine does the same thing. Why the hell would GM use a 24 gauge wire (translation, piano wire thin) in an area of the motor that you would work in. I'm guessing that my wire probably has a short in it somewhere, so I need to trace it back to the PCM and swap it out, but I plan on replacing it with something beefier, like 16-18 guage unless someone says otherwise.
Old Nov 11, 2007 | 07:14 PM
stevensLS1's Avatar
if yall follow the wire starting at the connector pin from the alternator and go up about 6'' you will see the wire flare out. thats where the fuse is located at. go down to the auto parts store and pick one up they are a few bucks. forget the technical term.
Old Nov 12, 2007 | 06:11 AM
UNDER PRESSURE MOD
I'll have to check that out. Thanks.
Old Nov 12, 2007 | 07:26 AM
ws6pewter's Avatar
Sweet I have the flickering headlights and the intermittent voltage drop too. Hopefully the fuse will fix this, I was having a hard time believing it was my alternator since it only has 27k miles on it.
Old Nov 12, 2007 | 07:49 AM
UNDER PRESSURE MOD
A quick question, if it were a fuse, wouldn't it be either an on/off type situation? If the fuse is blown, then no current is going to be getting to the alternator and you'd be running strictly off battery power and it would never charge.
Just thinking out loud.
Old Nov 12, 2007 | 05:13 PM
I checked the wire last night and went from the plug to about a foot up and then as far as I could along the fuel rail but still didnt find anything. Is this maybe a year specific thing? I have a 99 TA...
On another note, I was actually able to reinsert the wire into the plug prong but now I'm having trouble with the headlight motor turning and locks activating on their own when I'm just putting the negative cable back. I don't know if this is a relay thing or something but I really need help!!
Thanks,
Shawn
Old Nov 12, 2007 | 06:48 PM
UNDER PRESSURE MOD
Well, I pulled the plug off the top of the alternator and checked the connection and everything looked good. I undid the protective covering all the way back to #3 fuel injector and didn't see any fuse. I did pop the cover off the pcm, and checked the resistance from the pcm back to the plug and got 0.01 ohm, so if there is a fuse, it's not blown.
When I plugg the wire harness back in, it did seem kind of loose, so we'll see what happens the next time I drive the car.
Old Nov 12, 2007 | 08:22 PM
Alt's Avatar
Alt
A fuse is just a switch that you can't change by hand. Its either on or off a bad fuse would stop voltage from reaching its destination completely. Is it a short in the smaller than thermostat wire thats causing the voltage irregularities? I have a problem with an extreme dimming comming off of a rev or coasting down from like 25. Aside from that I have the normal voltage regulator issue of pulsing lights.
