poly motor mounts ftmfl!
Old Aug 13, 2007 | 09:15 PM
ls2 bait's Avatar
Default poly motor mounts ftmfl!
oh my god what a horrible job that was. took the better part of 3 hrs and cost me a knuckle full of skin. and ya theres no exhaust on the car either. i will never do that again. EVER.
Old Aug 13, 2007 | 09:40 PM
01CaMMMaro's Avatar
im sure itll be worth it though!
Old Aug 13, 2007 | 09:45 PM
WS6NIGHTMARE's Avatar
You did the right thing by putting them on while the exhaust was off though. Blood and cars go together nicely.
Old Aug 13, 2007 | 09:47 PM
LivingCanvas's Avatar
I agree. Worst install ever. Well worth the effort though
Old Aug 13, 2007 | 09:49 PM
ls2 bait's Avatar
it took me less time to get the entire exhaust and heads off the car then to put them damn things in! im still bitter. maybe ill be happy about it tomorrow. but my knuckle hurts now!
Old Aug 13, 2007 | 10:03 PM
ProjecT 9's Avatar
i have had the poly motor mounts sitting in my trunk for almost 1.5 years now and every time i read a thread about putting them in i let them sit longer. I'm really not looking forward to doing it...any tips you can give me though, things you would have done different? thanks in advance.
Jon
Old Aug 13, 2007 | 10:23 PM
ls2 bait's Avatar
really i had as much access as u could have with the k member in the car and it was the worst job ive done on the car yet. only thing i would have done diff was swap them when the k member was out.
Old Aug 13, 2007 | 10:26 PM
SoCal01z28's Avatar
+1 on worst job ever on the car. i did mine with the stock manifolds on and i thought for awhile the second bolt WAS NOT going to ever go thru. i got the motor out right now and i get to dick around with them again next weekend hooray!
Old Aug 13, 2007 | 10:32 PM
xBROKEx's Avatar
yeah motor mounts are one of those things its almost worth payin someone to do
Old Aug 13, 2007 | 11:01 PM
Fibbado's Avatar
I just finished up my poly motor mount install, PITA x 100 pretty much. I wrestled with the second bolt for two hours, only took me maybe an hour to get the LT's/AC and alternator off.
I gotta tell ya though, when that second bolt finally slid through I was freaking out like I won a million dollars thats how happy I was.
Now I'm wrestling with the trans crossmember trying to do the poly trans mount.
Old Aug 13, 2007 | 11:44 PM
SoCal01z28's Avatar
poly trans mount took me 15 minutes....
Old Aug 14, 2007 | 01:58 AM
Da Swami's Avatar
Yeah, it full on blows ***.
But the satisfaction when you're done is well worth the struggle. Just crank it up and watch the engine go "whut revving, I'm just chillin'."
Only problem is when people ask you what mod was the hardest to do on your car you can't point to some shiny headers or a fancy intake, you just have to wave down and say "those red things somewhere around that area were a BITCH."
Old Aug 14, 2007 | 02:08 AM
SpdFrk1990's Avatar
Yup pain in the *** install glad I did mine when I did the headers though.
Old Aug 14, 2007 | 02:54 AM
Striker289's Avatar
i did mine while i had no trans in car. Between all the disasembly and having to remove drivers manifold and cat. It took me close to 24 hours. and i ended up breaking on motor mount off in the block. had to replace two studs on the manifold, and both studs on the cat..... I cant wait to get my car running again. i hope theres a difference.
Old Aug 14, 2007 | 04:48 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It is a pain in the ***, but I didn't have that kind of trouble.
Old Aug 14, 2007 | 10:39 AM
blueeyeddevil141's Avatar
Jon
Hahah, same thing for me, they're just chilling in my garage...lol
Old Aug 14, 2007 | 10:48 AM
KRAZY K 2000 TA's Avatar
i left all the motor mount bolts to block loose and clamshell bolts it only took about fortyfive minutes to an hour tops with the exhaust off???
Old Aug 14, 2007 | 11:19 AM
Da Swami's Avatar
Good for you.
Old Aug 14, 2007 | 12:46 PM
95 Z28's Avatar
Hmm worst job you've done on the car? If you're saying that your cam swap was easier then I might have to order up a cam kit next paycheck . That's what I'VE been dreading doing. And yeah, motor mounts were not fun...at all.
Old Aug 14, 2007 | 12:52 PM
Tainted's Avatar
let me jsut say how easy it is to replace motor mounts when the motor is out of the car
