Comp Cams Full roller rocker adjustmant help
Old Aug 14, 2007 | 05:21 PM
123sugey's Avatar
Default Comp Cams Full roller rocker adjustmant help
I bought Comp Cams full roller rockers and need info on adjusting the valves from scratch asap.
THANKS
Old Aug 14, 2007 | 07:31 PM
chriswtx's Avatar
When I set mine up, .060 lifter preload was right at 3/4 turn after zero lash ... Seems most on here like to use between .050 and .080 lifter preload for stock LS1 and LS7 lifters. I used a dial indiactor to measure the preload on the lifter
Old Aug 14, 2007 | 09:25 PM
123sugey's Avatar
Is there a way to adjust them without a dial indicator ?
Where do i start ?
Old Aug 15, 2007 | 08:22 AM
123sugey's Avatar
Still need help !!
Old Aug 15, 2007 | 08:56 AM
chriswtx's Avatar
Just do the 3/4 turn past 0 lash and you will be fine...
