Head swap....how hard?
Mainly do you have to adjust each pushrod when tightening down the rockers like the old SBC's? How is it set up on the LS motors?
Any help is appreciated.
I'm new to the LS motors, but not to motors in general so I have no problem doing the work myself, just want to know what to expect.
i guess your a good reader though b/c you covered the basics of what to look for
nrmustang
i've done about six swap both heads and cam
each rocker need to be torqued down
on a scale of 1-10 i would give a head swap a 7 not too difficult just gotta clean the old gaskets off the block. and remember to put the ground on the back of the heads back on.
this should be very helpful for you
http://www.ls1howto.com/index.php?article=3
now go forth get your wrench on
to answer your question nrmustang the LS rockers are bolted down individually.
guys not trying to act like I know everything cuz I don't. but no one did reply when I saw his post so I figured I would give him some info that I did know. I knew someone else would help out. thanks
platinum WS6 just posted something that was worded funny man thats it no harm intended
Grind a slot in an old head bolt. Use it to clean the threads out for each hole. I put a small amount of grease on the ground slot and it will pick up alot of the junk. Next I take a shop-vac and duct tape a drinking straw to the end. This will "SUCK" all the junk out at the bottom, including antifreeze.
Remember, if there is stuff left at the bottom, you can crack you block.
Bob K.
Take your time & I highly suggest if your doin a cam too that you just start tearin it down from the top & take the cam out last. On reinstall go in with the cam first so you don't have to worry about droppin lifters & everything else is cake from there on.
Also use the ls1howto walk thru for guidence & torque specs.
