Throttle Body Bypass
my question is, I did this mod a couple years ago... however i never plugged up the two pipes coming out of the throttle body... is this a problem?
the mod is pratically free to do. all it does is by pass HOT coolant from entering the TB, so it makes it so that the air is cooler
That thing looks niiiicccee..
This is the only test I've found. It shows a 6HP 7FT/LBS peak gain, with an average gain of 5.6HP and 6.8FT/LBS. This testing was performed on a LT1, but I would expect similar results on the LS1 considering the similarity.
I can't see using any type of a CAI setup without bypassing the TB coolant. Seems like you'd be defeating the purpose, or at minimal not getting the full benefit.
