Grinding sound from front engine.
Old Aug 23, 2007 | 07:41 AM
tasilver's Avatar
Default Grinding sound from front engine.
Well at first I thought the sound may be the timing chain but now I have found out that cant be the it. So any ideas as what could make a metal grinding sound on the front of the engine. It seems to be coming from the passanger side. I had all of the pulleys replaced a few months ago. Anyone else ever had this noise. thanks for any help
Old Aug 23, 2007 | 11:45 AM
lostsurferguy's Avatar
powersteering pump?? i dunno man its hard to guess if you cannot hear what it sounds like
Old Aug 23, 2007 | 10:01 PM
98TA_vert's Avatar
might be bearing in the a/c compressor clutch or an idler/tensioner
Old Aug 24, 2007 | 05:56 AM
tasilver's Avatar
The sound is comming from the front passanger side of the engine. Can the water pump make noise if it is going bad? I can not drive my car on the road (still fighting a title mess up with dmv) It makes the sound at idle. The faster you rev the faster the sound.
