Getting new heads, which header bolts should I use?
Old Aug 24, 2007 | 12:20 AM
SweeTbone's Avatar
Default Getting new heads, which header bolts should I use?
I'm picking up some TSP 5.3L Stage 2.5 Heads, so I'm looking to see what I should do for bolts. I re-used my stockers the first time around. I have them back out now getting ready to pull the heads, but they look a little beat. I'm sure the cosmetic look is not affecting the bolt itself. I do have the bolt that Kooks sent with my headers, but the head is way bigger than 10mm. Probably standard. Should I re-use my stockers, buy new stockers or use the Kooks bolts in the brand new heads? Thanks.
Old Aug 24, 2007 | 02:28 AM
njc.corp's Avatar
use new stockers if the old ones are run down-
also if u got the kook ones why not use them-save yourself the future expense even though bolts don't cost that much-
Old Aug 24, 2007 | 04:55 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
If you have everything apart anyway - I personally wouldn't waste my time on ANY bolts.
Go with ARP Head Studs. They aren't that much more $$ and are worth it for reliability and peace of mind (plus you won't have to worry on future head swaps about getting all water out of tapped head bolt holes in block to prevent block breakage).
Just my .02
-Jay-
Old Aug 24, 2007 | 07:29 AM
g-ryde1's Avatar
Just my .02
-Jay-
+2 on the studs good choice
Old Aug 24, 2007 | 08:20 AM
SweeTbone's Avatar
Thanks for the tips fellas, but I already have ARP Head Studs. I'm looking for HEADER bolts, not head bolts. Like I said, the stockers could be cleaned up a little, but I was wondering if that would have any adverse effect if they weren't that clean and if I should just get some new ones.
Old Aug 24, 2007 | 08:28 AM
1QUIKWS6's Avatar
Ah, my bad. In that case, I use Breslin Split Lock header bolts or you could go with Stage8 Locking header bolts. Both styles accomplish the same thing but the Breslin's are easier to use.
-Jay-
Old Aug 24, 2007 | 08:31 AM
tylerdj's Avatar
I would reuse your stock header bolts. Just clean the threads up some before you reinstall them.
Old Aug 24, 2007 | 11:38 PM
g-ryde1's Avatar
When i installed my headers (LT) I went ahead and bought the ARP Header studs so much easier to hang the headers and good clean look. def worth the extra money i think.
Old Aug 25, 2007 | 12:17 AM
bsf's Avatar
bsf
I only have experience w/ stock bolts and Stage 8 bolts. I upgraded to Stage 8 bolts basically because they are shinier. Since they are included, though, I did install all the clips and retainers. I bent almost all the retainers to fit snugly. My header bolts will not be backing out of their own volition.
Old Aug 25, 2007 | 07:57 AM
99FormulaM6's Avatar
what are the length of the bolts?
Old Aug 25, 2007 | 01:44 PM
JPH's Avatar
JPH
arp 12pt. stainless #771-1003 and buy 3 packs of this part #.
Old Aug 25, 2007 | 01:46 PM
lastcall190's Avatar
+1 for header studs.
Old Aug 25, 2007 | 02:31 PM
ShevrolayZ28's Avatar
I have the Breslins, $5 per bolt. I only worry that down the road they might be difficult to remove. After being on my garage queen for a year, they did, however, come off easily.
I wouldn't hesitate to use the Stage 8 bolts. They're cheaper and work well.
Old Aug 25, 2007 | 04:24 PM
davered00ss's Avatar
Moderator
Use the bolts Kooks sent witht he headers. Stage 8's are great. ARP head studs suck.
Old Aug 25, 2007 | 04:42 PM
NemeSS's Avatar
stage 8 for ls1, very good product
Old Aug 25, 2007 | 04:59 PM
jimmyducati's Avatar
just installed my xs headers, went to lowes and got some heat tempered small head allen bolts in the right pitch, the small allen head made the install much easier!
Old Aug 27, 2007 | 03:42 PM
Rob Hood's Avatar
Stage 8 p/n 8900 for the 25mm length. Just spoke with one of their reps (Glenn, 1-800-843-7836) and he said that was the kit to use on LS-motors.
Old Aug 27, 2007 | 04:13 PM
robertbartsch's Avatar
Use thread lube since the bolts will go into aluminum.
Old Aug 27, 2007 | 04:23 PM
tylerdj's Avatar
Why are the header studs so much better? I've never used them before and am curious since a lot of people seem to be recommending them.
