which cam
Old Aug 28, 2007 | 02:33 AM
ChevyRyda99LS1's Avatar
Default which cam
I got a 99 z28 I want to purchase a cam a small one I dont want a supercar just a decent little power boost I live in california and deal with the emissions laws also I have a automatic and I dont want to have to get a torque convter I was looking at this 63-LS-212/218 Comp Cams LS1 Camshaft - 212 / 218 .522 / .529 114 LSA 1200-6000 RPM Power Band. Excellent low-end power. Mild Camshaft, great for automatic cars with the stock or mild aftermarket torque converter and daily drivers. Works well with Crane 1.8 Roller Rockers. Its on thunderracing.com any adivce you guys can give me?
Old Aug 28, 2007 | 09:34 AM
teke184's Avatar
get somethign with more lift built in...save the expense of the rockers and you won't be leaving power on the table.
the TR 224 on a 114 lobe has shown to pass emissions in cali on lots of cars, with the right tune.
i've even hurd of guys running 2 ECMs so that they can have a hot tune for the street and a "smog" tune for the test.
Old Aug 28, 2007 | 09:43 AM
tylerdj's Avatar
212/218 is not a mild cam, that is a very small cam. Cams such as the 224/224 are very well known for producing good power throughout the power band as well as having great driveability and working well with the stock converter. I had the 224/224 on my other car with the stock tune and drove around fine for quite a while.
Old Aug 28, 2007 | 09:44 AM
tylerdj's Avatar
By the way, you really should read through several of these threads on this LINK . They have some GREAT information.
Old Aug 28, 2007 | 01:44 PM
BLOWN SS/T's Avatar
Here 's the thing, they guy wants a cam that will give him some extra power. He dosen't drive the car too hard and has been made aware of the problems of the A4. So he doesn't plan having to get a rebuild soon. He wants too use his stock stall, and gears. I personallly recommended the 224. But that would probaly need a higher stall.
What do you guy's think about the hot cam with stock stall. Idea is to add some power with a cam and tune, but not stress the trans as much as possible.
Old Aug 28, 2007 | 02:26 PM
tylerdj's Avatar
I think the people that have switched to a hot cam are generally pleased with the decent bump in hp. I know many people that have run the 224 on the stock stall and still have great 1/4 mile times.
Old Aug 28, 2007 | 03:30 PM
Jantzer98SS's Avatar
One option is the LS6 cam for cheap $100 in classifieds.
A popular choice in cali is a 218/218 114
I don't know if it will pass emissions but a 224/224 114 is a NO BRAINER if it will pass smog for you.
Old Aug 28, 2007 | 03:34 PM
01Z0H6's Avatar
I am running the G5X3 in my DD... Sweet!!
Good luck
 Michael S. Palmer
Old Aug 28, 2007 | 03:40 PM
BLOWN SS/T's Avatar
Main thing is he's not planning to make the extra expense of having to rebuild his A4 anytime soon, so he wants something that can give him some extra power and still not beat up the trans to bad.
Old Aug 28, 2007 | 03:57 PM
tylerdj's Avatar
The cam won't affect his trans.
Old Aug 28, 2007 | 05:44 PM
01Z0H6's Avatar
Well... not necessarily...
Mine is definately in need of a rebuild...
405 rwtq on my high mileage 4L60E is showing a "little"
wear...
Good luck
Originally Posted by tylerdj
The cam won't affect his trans at all.
Old Aug 28, 2007 | 07:27 PM
INMY01TA's Avatar
I'd never put anything smaller than a 224 in mine.
Old Aug 29, 2007 | 04:51 AM
BLOWN SS/T's Avatar
The guy is looking for some extra power and since we all know how an A4 will react to heat and extra rpm, he's looking for somthing that wont stress the trans to much.
You guys think he could get away with a 224 and stock stall?
Old Aug 29, 2007 | 09:48 AM
tylerdj's Avatar
Yes, I drove like that for well over a year and the guy I sold the car to is still driving it with that cam on the stock stall with no problems. The cam isn't going to wear down on his transmission, the only thing that will stress the tranny is a stall or how he drives the car.
Old Aug 29, 2007 | 11:16 AM
teke184's Avatar
spend an extra $150 and install a good trans cooler....geez.
any increase in power has the potential to damage a transmission, or to at least shorten it's life. but there is no way to say "this cam will but that cam won't" when it comes to the choices you're listing.
like i said above, heat is the major killer of the auto trans...so get a cooler and you should be fine.
Old Aug 29, 2007 | 05:54 PM
BLOWN SS/T's Avatar
Yeah I'll support the trans cooler.
Heat and rpm is the main thing that will kill a trans. I also doubt a cam will destroy the A4, and if it has a conservative tune less worries.
Old Aug 29, 2007 | 08:54 PM
thanks very much for all the help
