air removal
Old Sep 5, 2007 | 08:54 AM
LS1ne's Avatar
Default air removal
ok long story short got through most of the procedure in removing the air system on my 2000 trans am. Now im stuck. I cant remove the little black saucer that the vaccum plugs into. Done the search option and know about the bolt behind the motor. question is how do you get to that bolt. Is there any other option on removing the part? ANY help is appreciated.
Old Sep 5, 2007 | 09:31 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
If I remember correctly the bolts are screwed into a rubber isolator. You should be able to get two of them out and yank the motor off the bracket
Old Sep 5, 2007 | 09:55 AM
JScamaro's Avatar
I must have been lucky. When I pulled on the tubing to get it out from the back it just came right out for me. It must not have been bolted on very well.
Old Sep 5, 2007 | 11:16 AM
LS1ne's Avatar
rubber isolator? thanks for the replies
Old Sep 5, 2007 | 01:16 PM
Ripper415's Avatar
on mine i looked for a bolt by feel but couldnt find one so i really yanked hard and something popped off. after looking at the unit it appears that it was held on by some kind of plastic clip instead of a bolt. i have an 02 ss so maybe yours is different?
Old Sep 5, 2007 | 04:25 PM
JScamaro's Avatar
I have an 02 SS as well and mine was definitely not bolted on.
Old Sep 6, 2007 | 08:51 AM
LS1ne's Avatar
got another day off, round two of the air delete. i found an egr blockoff plate down @ the bottom of my toolbox yesterday. most likely gonna clip the egr as well. this should go alot smoother, thanks for the replies guys.
o one more question, any thoughts on adding a small catch can? stang killa on this forum whipped up a nice piece i saw on this site. interesting...
