Which fitting to use when recharging AC?
Old Sep 6, 2007 | 10:21 PM
sdiddy's Avatar
Default Which fitting to use when recharging AC?
I understand the process, but am unsure which fitting to use when recharging. Is it the fitting on the line that goes to the condensor (right next to the radiator)? If you have a pic that would be great!! TIA!
Old Sep 6, 2007 | 10:57 PM
sdiddy's Avatar
Someone...anyone???
Old Sep 7, 2007 | 08:50 AM
Insyder's Avatar
^^ttt
Old Sep 7, 2007 | 09:07 AM
jimmyblue's Avatar
Moderator
Line from compressor to condenser is the high
pressure side, you can't push freon in there.
The fitting on the run from firewall to compressor
is your low side. If you have the cheapo fill kit
then you don't have to worry because the two
connectors are different diameter unlike older
R12 cars with all the same Schrader everywhere.
The only way you could screw up is if you had a
manifold gauge set hooked up and ignored the
pressure readings.
Be sure to fill with vapor (right side up) and not
liquid because there is no distance from port to
compressor. A tub of hot water will speed it up
once the can is open and starts to chill itself down.
Old Sep 7, 2007 | 10:13 AM
Insyder's Avatar
I'll have to look at it again when I get home from work. So, I connect the 134a to the fitting on the accumulator, or the fitting that is right near the condensor? Thanks.
Old Sep 7, 2007 | 08:32 PM
Ping King's Avatar
charge from the port on the accumulator. Charge with gas and not liquid if you can. Its very easy to overcharge when using liquid, even though there is an accumulator.
