FAST 78mm TB cable placement andadjustment
Old Sep 9, 2007 | 09:28 AM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
Default FAST 78mm TB cable placement andadjustment
i had my friends TB off to make a WOT switch bracket for his nitrous, I forgot which of the 2 holes it was on the TB. I have it on the furthest hole. I adjusted the cable to be sure that the throttle cable is the correct length.
I am going to place it back in the "shorter" slot and adjust the cable back. the thing was the cable was never set to 100% WOT to begin with.
For those that have done it did you use the top slot? the car idles at about 2000 rpm and then dlowly comes back down. when i am on the highway with the car it is like it has cruise control on.
tia!
taner
Old Sep 9, 2007 | 10:49 AM
studderin's Avatar
On the TB 98-00 car use ther upper hole (small cam TB like on the TB's)
01-04 is the lower hole (larger cam TBs)
also the non CC/TCS thottal cable last numbers is 59 for the 98-00 cable, and 60 for the 01-02 cable.
Old Sep 9, 2007 | 07:46 PM
taner's Avatar
thank you! i set it up on the lower hole, car is an 02 SS. i readjusted the throttle cable and RESET the TPS, that might have been the culprit! either way it seems to be ok for now!
now i need to figure out where the wire for the msd shift light is from the PCM.
Old Sep 9, 2007 | 08:17 PM
studderin's Avatar
pin 10 on the lower PCM conector, it will be a white wire.
Old Sep 9, 2007 | 10:01 PM
taner's Avatar
found it thanks! i did a search and someone had a great picture! just need to wire the +12v and ground.
