Which MAP sensor for Fast 90mm intake? also what intake bolts?
I am going to order a Fast 90mm intake.
What do I need besides gaskets?
Do I need new intake bolts?
I don't have the old map sensor, can I use the Fast Map sensor?
307007 Map 1 Bar Sensor
307008 Map 2 Bar Sensor
307009 Map 3 Bar Sensor
Which one if so?
Any part numbers for intake bolts if needed?
Also I plan on getting the Fast 90mm TB. Is there anything new I will need for it?
Which one if so?
Ok
1. I need FAST gaskets
2. It comes with intake bolts
now the only question I have is about the MAP sensor
Would I maybe need to use a MAP relocation kit?
edit: I was ablt to buy a GM Map sensor from TSP.
