HELP??? #8 primary glowing
Old Sep 13, 2007 | 07:51 PM
NASTY98TA's Avatar
Default HELP??? #8 primary glowing
Alright so far i have done a compression test and it is 155 PSI, I have have listened to the valvetrain and it sounds ok, I changed the plugs why Only this one cylinder?
Thanks
Brian
Old Sep 13, 2007 | 08:14 PM
FASTFATBOY's Avatar
How is your fuel system setup? Move the injector in #8 and see if the problem moves with it.
What did the plug look like?
David
Old Sep 13, 2007 | 08:25 PM
NASTY98TA's Avatar
Default Injector
I swapped the injector and it is still the same thing, the plugs look a little white, but all of them are consistant.
Old Sep 14, 2007 | 04:48 PM
FASTFATBOY's Avatar
Pic of your fuel system, the way it is arranged. What fuel rails etc?
David
Old Sep 14, 2007 | 05:56 PM
Wnts2Go10O's Avatar
sounds like the rail may have some crap in it
Old Sep 14, 2007 | 05:58 PM
jimmyblue's Avatar
Moderator
#8 is going to see the least cooling airflow, shrouded as it is by
the firewall and the A/C clutter. Plus it's the darkest part of the
engine compartment so will show better. If you look at them all
at night, do they appear more balanced?
Old Sep 15, 2007 | 09:53 AM
AutomagicLS1's Avatar
Have you used a laser thermo heat gun and looked at the primarys to see what the temps are idling? Ive got 3 that are near 700 degrees idling turns out I have a voltage issue to the injector connectors which I think come strait from the pcm. Anyway off subject but I was just trying to find out how hot they were
