Meziere Water Pump???
Old Jun 8, 2003 | 03:32 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Meziere Water Pump???
Unless Terry rigged his by adding a fitting for the heater hose, and an inline t-stat... I think he actually did make his a street version.
We are waiting for dyno numbers.
I bet the pumps will retail over $500 but I hope they are less.
Old Jun 10, 2003 | 04:10 PM
2001CamaroGuy's Avatar
If they do that BS!!!!!
Thats the biggest problem with the LS1.....everything costs 2 or 3 times as much as a SBC (hell....a Meziere SBC pump is $270 from summit...)...its just not right....
Old Jun 10, 2003 | 06:59 PM
Reckless's Avatar
Super Moderator
So what is unstreetable about the race version? No heat? If that is all, I will get the race version. Who needs heat?
Old Jun 10, 2003 | 11:58 PM
GeorgeC's Avatar
No heater or thermostat provision, and you have to figure out a way to take care of belt routing/tensioning depending on waht accessories you've still got on the car.
It was simple for me, since all I have is an alternator.
I love my Meziere EWP...
Old Jun 11, 2003 | 07:24 AM
Reckless's Avatar
Super Moderator
That's what I will be doing George. Alternator only. So how do you tension the belt? Just slip it on before mounting the alternator? And I guess you run without a t-stat?
Old Jun 11, 2003 | 08:49 AM
GeorgeC's Avatar
Todd, if my car wasn't apart, I would send you some pics... It's actually really simple, but hard to explain.
I made the alternator adjustable in the factory bracket, and just use a tiny little belt. I tension it with a prybar, then have one bolt to snug down for the adjustment. I made a little "adjustment" slider (out of aluminum flat bar)that bolts on to the back of the alternator.
Old Jun 11, 2003 | 02:04 PM
The Juggernaut's Avatar
What size is the belt,George?
Old Jun 11, 2003 | 02:47 PM
Reckless's Avatar
Super Moderator
Thanks any way George. No rush, mine will be down for a while as well
Old Jun 11, 2003 | 05:35 PM
VTtransam's Avatar
Check out the internal section. They put the first one on Jsears' car on monday for testing. If testing goes well, they will go into production "very soon" There is a good thread in the other section about this pump.
Matt
Old Jun 22, 2003 | 09:47 AM
stealth's Avatar
Is anyone aware of a high amperage alternator, say, 130 amps, for an LS1?
Old Jun 23, 2003 | 04:21 AM
JB98Z28's Avatar
In the most recent Summit catalog I received they have an EWP for LS1's in their new stuff section. It says it is a street version and its made by meziere. I dont have it in front of mee I think it said it had provisions for belt routing.
