Location of Oil Sending Unit?
Old Jun 3, 2003 | 02:42 PM
SixSpeed's Avatar
Default Location of Oil Sending Unit?
Hey guys. Easy question. Where the hell is the oil sending unit at?
Old Jun 3, 2003 | 02:55 PM
TaTommyWS6's Avatar
Default Re: Location of Oil Sending Unit?
Behind the intake manifold, in the center of block, a little closer to the driver's side.
The pic below shows where it is located(right middle of pic)
http://www.ls1howto.com/howto/ls6pcv...er_removed.jpg
Tommy
Old Jun 3, 2003 | 03:44 PM
SixSpeed's Avatar
Very cool. I don't have many tools, so hopefully that won't be to much of a bitch. The diagram I saw said oil pressure sensor. I was wondering if that was it. Thanks man.
Old Jun 3, 2003 | 04:25 PM
Ditch Digger's Avatar
When I broke mine I had to remove the intake and the valley cover inorder to remove the old one. If you can find an extra deep socket you could probably replace it with the intake still on.
Old Jun 3, 2003 | 04:57 PM
SixSpeed's Avatar
Excellent! Hopefully the deep socket will work...
Old Jun 3, 2003 | 05:12 PM
minivette's Avatar
The deep socket I bought at Sears didn't work. But, O'Reilly's had a OPSU socket for around $5 that was perfect.
Old Jun 4, 2003 | 09:45 AM
SixSpeed's Avatar
Cool, is that a half inch socket?
Old Jun 4, 2003 | 10:08 AM
BigRay77's Avatar
when i replaced my knock sensors i broke my oil sensor as i pulled the intake cause there is a hose that runs to the master cylinder....i broke it off to the metal nut so i just used a socket to get it off.....of course i broke the new one that i bought while putting it in .....dont use a pair of channel locks to put it on .....i had to go down to my buddies shop and he had a special deep *** socket that came in 3 seperate pieces and that worked!....not to freak you out or anything but it was a PITA!!!! for me anyway.....of course i am a slightly overgrown 6'4" 340 pound man....GOOD LUCK!!!
Old Jun 4, 2003 | 10:17 AM
SixSpeed's Avatar
Ouch...That's not good. Well, you got about 160 pounds on me. You better start moding that thing so you can see some low 13's.
Hopefully the deep socket that minivette used will keep me out of trouble.
