how much power am i losing?
Old Sep 23, 2007 | 10:50 PM
cassfrc's Avatar
Default how much power am i losing?
How much power am i losing by having a stock throttle body with my setup? Mods in sig.
Old Sep 23, 2007 | 10:51 PM
Tainted's Avatar
prolly 5-10, get a ported stocker
Old Sep 23, 2007 | 11:57 PM
Starz T/A 17's Avatar
yea and your really not loosing any, your just not gettin the full pontential out of the one thats on there. And I would say 5-10 would be a fair estimate
Old Sep 24, 2007 | 05:27 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You should look at it as how much power will you gain.
Old Sep 24, 2007 | 07:33 AM
Dragkid1917's Avatar
True, I cant gve a number, But its not lik you have a fast 90 intake, so it may not be that much. The dyno guys said that you would pick up 15 rwhp with a fast 90/90 combo over an ls6 intake/ stock TB. That was with my cam only motor so maybe you would get 20 outof it at most. Having sad that, 5 RWHP sounds good. 10 would be great.
Old Sep 24, 2007 | 11:31 AM
green28's Avatar
It's worth doing and its a great bang for your buck mod. Felt like it helped with throttle response as well if you get all the little tricks done, ie. bump stop mod
Old Sep 24, 2007 | 04:04 PM
Fb0dy0nly's Avatar
might as well just save up and get the 90/90 combo when you can instead of throwing money at the stocker because that will give you some good power and you will need it or should I say, it would really help if you add anything else to the car. After doing heads and cam, it is a good time for the 90/90 setup but when is it never a good time to install new parts....
Old Sep 24, 2007 | 05:04 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Port the stocker like everyone else has said
