Strange Exhaust Rattling...
Old Sep 27, 2007 | 01:34 AM
ssbandit158's Avatar
Default Strange Exhaust Rattling...
I have an 01 SS and for some strange reason the exhaust has a rattle at idle, I've had it on a lift and hit the exhaust with my hand and I can hear it but it doesn't seem to be coming from anywhere on the outside. I thought it was the o2 sensor crush collars so I put some high temp sealent on them but the rattle remains. I had a buddy of mine say the cat may be broken on the inside and I also recieved a recall letter from GM saying some cats are going bad, anyone else have this problem?
Old Sep 27, 2007 | 02:00 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Are you sure it is not hitting the floorboard?s
Old Sep 27, 2007 | 02:41 AM
No Its definitly in the exhaust somewhere twords the front. Everything is tight and where it should be. Its just really annoying and it makes my car sound like I let evil kenevel ramp it over a bus or something.
Old Sep 27, 2007 | 07:11 AM
jag42420's Avatar
Broken ceramic in the cat can rattle, but usually it follows an impact of some sort. Have any other cat related problems (running warmer than usual, loss of power, exhaust smell different, engine revs slower)? You could always drop by a local dealer, as the cat fix is free with the 'not a recall' letter they sent out. If you've checked everything out externally and see nothing a cat would be my next suspect.
Old Sep 27, 2007 | 03:48 PM
Yeah I went to the chevy dealership and tried to convince them to put in some high flow cats but they would only put in factory cats. Oh well I think I will just go ahead and get some nice ceramic coated headers with duals. Hopefully that will solve it, if not then I have some serious problems.
Old Sep 27, 2007 | 03:56 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
high flow cats.??? at a dealer.???
Old Sep 27, 2007 | 05:41 PM
Black35SE's Avatar
I have the EXACT same problem on my 02 Z28. Sounds like a metalic rattle or kinda like heavy change in your pocket rattling around? Its hard to describe to the idiots who work at my dealership too. My cars going in next week I'll ask them to look at the CATs thanks, u may have helped me out
Old Sep 27, 2007 | 10:03 PM
01 Red WS6's Avatar
I have a rattle on my exhaust too but I can't seem to find the problem. It's not cat related for me since I don't have cats.
Old Sep 27, 2007 | 10:57 PM
sixvi6-camaro's Avatar
I had the exact same problem. turned out to be the Ceramic inside the rear O2's was broken and rattling around. its easy to check. just take out the rear O2's and shake them. If they make a noise that is the problem.
Old Sep 27, 2007 | 11:47 PM
GMmexican's Avatar
I had the same problem as you, it was towards the front on the drivers side, all i did was tighten down every single bolt on all the heat shields on that side and the rattle went away, and made sure the driver side exhaust manifold bolts were tight
Old Oct 3, 2007 | 03:45 AM
Arad's Avatar
I have the same thing at high rpm's. Hey, I'm not too far from you in wentzville! Let me know how it goes.
Old Oct 3, 2007 | 09:32 AM
PureWS6's Avatar
I have a rattle like that at idle. It comes and goes...but it is rather annoying.
Old Oct 3, 2007 | 12:26 PM
discostu's Avatar
i also had a problem with that noise it was a mounting bolt next to the trans on the passanger side had striped. just took it out but in a new bolt and lock nut and the noise never came back
Old Oct 3, 2007 | 12:27 PM
discostu's Avatar
i also had a problem with that noise it was a mounting bolt for the exhaust next to the trans on the passanger side had striped. just took it out but in a new bolt and lock nut and the noise never came back
