Ok, What the f@*k is this??
Anyone know what this thing is?
Anyone have a part number for it?
Also, could this be the cause of the whining sound I've been hearing that would rise with the revs of the car (its about where I thought the sound was coming from)?
Finally, how do I take this thing out to replace it?
Thanks!!!
Great, What is the size is the metal part, I couldn't get a socket over it, I guess I need to get a wrench for it.
I guess I'll just keep corssing my fingers, I know this thing had to be broken before the intake came off. I might have finished it off a bit, but it had to be cracked at leased.
Like mentioned already, it happens all the time. It didnt happen to me because I knew from reading all the threads about people breaking them how to get intake out without breaking it.
everyone on here just says that thing snaps off really easy because of its location. not because its loose,
hard to believe but that one was just a screw up on GM's part from the factory (aka, window motors, bubbling sail panel and stupid coolant through throttle body)
If you don't suck at life, you would have noticed it before you pulled the intake.
And the whistling is probably your alternator. Lots of people have a whine.
not true, my sensor was left off after i put my ls6 manifold and the psi sat at 0 but my check gauges light wasn't on. the sensor can be picked at autozone for around $40 you'll need a sensor socket, $5-8 i believe
