Solid Motor Mount Install Idea.
Old Jul 17, 2010 | 03:20 PM
Cumbias's Avatar
Originally Posted by 98RedBird
Solids are CAKE to install. Much easier than poly's. Just throw a block of wood under the oil pan, lift it up, pull the old mounts out, and throw the new ones in. Not hard at all. I've had both and I like them both. They both have their pluses. FWIW, I didn't really honestly notice much of a difference in vibrations jumping between stockers, to poly's, to solids...
The one's that tell you that they are going to rattle your teeth out are ignorant and haven't tried them. They just want to SOUND like they know what the hell they're talking about...
I thought you couldn't lift the engine from the oil pan. How did you imlement the block of wood to lift it?
Old Jul 17, 2010 | 03:46 PM
Aetos's Avatar
I just put a big yellow telephone book between the jack and oil pan and jacked it up slowly
That sounds so true, before I bought my solids I did a lot of research and noticed everyone that said they cause way too many vibrations didn't actually own solids. Don't get me wrong, solids DO cause more vibrations, but they're really not that noticeable(on most occassions) and make the car feel more like it should IMO. and on the plus side, most girls will probably like the extra vibrations on the seat
Old Jul 17, 2010 | 05:20 PM
99SSJarhead's Avatar
place the wood between the jack and the oil pan. It really isn't much more complicated than that. You just need a piece decently long and wide enough to spread the weight across the wood. Just not so long that when you start jacking it up it doesn't catch on something.
Old Aug 30, 2010 | 06:43 AM
Grifter's Avatar
Very, very true. You'll notice that with a lot of aftermarket parts. People tend to give their opinion even though they've never tried it.
