Z06 MAF Center Bar Removal???
I've got a 408 and am going with a Fast 90, thus the reason for the 85mm MAF. I'm wondering, if in actuality, the old LS1 MAF will flow more CFM's?
Any time you modify the MAF, you will need to rework your MAF PCM table.
if you are refering to the wedge looking divider, you can remove it. personally, i think the whisper ends are going to end up with about the same overall inner diameter as the Z06 MAF has. do you have a way to measure the overall diameter of each one?
A friend of mine asked about the LS7 MAF, which never occured to me. Has anyone tried it, and I wonder the diameter is.
hype type numbers, they look good and mean nothing.
This is because your motor is a fixed displacement
pump and moves a fixed amount of air naturally, from
which you only see a short-fall varying with components.
What you really need to know, is your BARO (outside
pressure) and your big-end MAP (manifold pressure).
BARO-MAP is where it's at. (BARO-MAP)/BARO is your
percent of not-realized horsepower.
The thing is, when vendors talk about CFM it's CFM at
an inch or three of water. That's like 0.25%, an inch of
water is, of atmospheric pressure. So if you rate flow
at 500CFM @ 2"H2O that means, at 500CFM the piece
is costing you 0.5% of ideally-realizable output. So
swap it for a 1000CFM piece and knock that 0.5%
down to 0.3% for a big 0.2% gain? Yeah.
If you do arithmetic for a hobby you can kind of back
meaningful pressure-drop numbers out of the brag-CFM
but if you start with that you'll buy a lot less stuff.
Good for you, bad for them. Not easy though to get
the test conditions out of the blurbs, usually, though,
so you have to assume they stuck to "normal" basis
(whatever that may be for EFI air-side plumbing).
Upping the "H2O testpoint is an easy way for them
to make their stuff look better, for free.
My take, if it's a 1000CFM machine then it'd help but
by then the meter is off the scale and you're done
with MAF based control. So fuggedaboudit.
What about the LS7 MAF any experience with that? Thanks
GM stock table from that platform. Remove the vane
and all bets are off. Though, I can see if you had a
stock reference MAF and frequency meters, you
could port it slowly until you got to general agreement,
ported 85mm will come up toward stock airflow/freq as
you remove material. There's no guarantee, and low odds
that you'd totally match more than a couple of points
on the curve. But worth a try maybe if you've got the
gear and the spare time.
First order, though, if your MAP reading at redline is not
below 98% of your midband WOT MAP then all the intake
tract is "good enough". Only if it's fading more than that,
do lid/MAF/hose/TB have any big 2% contribution to offer.
The modified LS1 MAF has more open area, but if I understand you correctly, that is not the real, valid parameter in evaluating MAF flow, and ultimately performance. Thanks
Also any comments on a LS7 MAF would be appreciated.
