What does a Cam do for you?
Old Oct 8, 2007 | 12:48 AM
Whiteknight01's Avatar
Default What does a Cam do for you?
Alright guys I have a ws6 with flowmaster exhaust with a 3inch cutout. Can someone tell me what would happen if I put a cam on my car? what is a cam? Thanks
Old Oct 8, 2007 | 08:56 AM
Horsepwraddict's Avatar
just putting a cam on your car isnt going to do much lol
a cam is a part inside your engine, it runs off the crankshaft via a timing chain and operates your valves.
Old Oct 8, 2007 | 10:55 AM
Zero4488's Avatar
Restricted User
Thanks for the websters answers....
Old Oct 8, 2007 | 11:16 AM
no problem
Old Oct 8, 2007 | 11:22 AM
Ericbigmac83's Avatar
Start by reading this, and the camshaft is internal, not external btw
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Old Oct 8, 2007 | 11:25 AM
silver-mod-o's Avatar
Custm2500's #1 Fan
SEARCH...
are you kidding me??
Old Oct 8, 2007 | 11:26 AM
BIG_MIKE2005's Avatar
LOL, comming from a neewbie. (don't take the above advice)
Tell this too all the cam only guys making 400 RWHP.
Generally if you add just a cam you also at least need to add some better valvesprings for the higher lift on the aftermarket cam. Of coarse you'll see better gains if you also add all the extras like full exhaust & heads for example.
Goin cam only is a route alot of members take & then add heads later since they cost a good bit more than just a cam swap. There are several cams considered reverse splt that are designed to work with a stock head set-up also.
Old Oct 8, 2007 | 11:33 AM
Pro52R's Avatar
Well..not to be a smartass or dick..
With a question like this. I advise you to not install it yourself...
Old Oct 8, 2007 | 11:43 AM
ArcticZ28's Avatar
Well, depending on the cam, it can add 2-3" to your peter, but that's about it.
Old Oct 8, 2007 | 11:49 AM
I think you missed his sarcasm....there was a subtle joke about setting a cam on top of the car not helping because it has to be installed......get it.....its funny
Old Oct 8, 2007 | 01:40 PM
at least somebody got it
Old Oct 8, 2007 | 01:45 PM
bjamick's Avatar
A cam will will help more air to get in the chamber and also get that air back out of the chamber. More air = more power.
Old Oct 8, 2007 | 05:18 PM
I know I can't put it on myself because I dont' even know what it looks like. HOw much do they cost? I don't know anything about cams but I know they make it sound choppyer and thats what I want to do.
Old Oct 8, 2007 | 05:36 PM
tripps's Avatar
Well more than sound, it has a dramatic increase in HP. The cam is like the "brain" of the engine, controlling the valves for when air, gas and exhaust all enter/exit the engine. They usually cost around 350-600 dollars, all depending on which kind you get.
Before you do a cam, i would suggest longtube headers and full exhaust. it would greatly enhance the gain from your cam. Also, start researching..
Old Oct 8, 2007 | 06:41 PM
porksoda's Avatar
If you want the sound just pull a spark plug wire!
Old Oct 8, 2007 | 08:32 PM
rsodeputy61's Avatar
aaaaaaaaaaahhhhhhhhhhahahahahahahahahhaah!!!!! lmfao!!! that's funny right there, i don't care who you are!
Old Oct 8, 2007 | 09:13 PM
RedRallyeZ's Avatar
https://ls1tech.com/forums/showthread.php?t=327734
read that thread, all the way through. it will tell you much more than you ever thought you needed to know
Old Oct 8, 2007 | 11:49 PM
slow1999blackz28's Avatar
To the OP i just read your other post about the cats and mentioned to ask about a cam guess you were miles ahead of me on this one.
+1 on the cam thread after reading that through your going to know a thing or two
Old Oct 9, 2007 | 12:13 AM
God help me
Old Oct 9, 2007 | 12:24 AM
z28ss4me's Avatar
WhiteKnight, don't stress my friedn, about 5 years ago I was wondering the same things. A month ago I just installed my first cam. Read the stickys and take your time to learn about the car and what things do what so you get the parts you need to achieve your desired results. It's all good!
