Cali EGR question for smog
My guess would be that if there's no code being thrown, I'm fine. Anyone have any experience with this?
If you live in Cali and your car came with the EGR you need to have it on the car functioning to pass smog. They hook up the car to the computer and that tells them everything about the car. I was in a similar dilema when I installed my LS6 manifold on my '99 Formula. I told my tuner mechanic that I needed to keep my EGR for smog reasons. He basically drilled a hole where the EGR goes and I got the EGR kit from Lingenfelter. This kit holds the EGR fitting to the manifold.
I passed the visual. I passed smog. The price you pay for living in Cali.
You can chance it if the shop lets stuff slide. If the shop crosses every T and dots every i your are in trouble.
however, he says that these tech's dont know what year car has what, so what you do is remove all the stickers and diagrams in the engine bay displaying your air and egr systems...
Then the tech has no idea if your said year has to have air or egr, thus it slides. This is not picked up in the pcm check as then the codes have been tuned out. just passing on information...
as far as the computer thing goes, as long as theres no service codes and you pass the sniffer youll be fine. what your tuner did was he turned off the service code for the EGR and maybe even the AIR. this allows you to remove the systems and not get a SVS light.
im glad to live in texas.....you just give a guy 10 more bux than what your supposed to pay...and your set for another year
