Relocating coil packs/extending harness, specific routing for harnesses?
I no longer have my stock coil pack brackets that bolted to the valve covers because I had planned on relocating the coil packs. I want to mount them under the cowl, which would mean that I would need to extend the harness/plugs.
My question, does each individual plug go in a certain spot? In other words, there are 2 harnesses on each side of the motor. Each harness supplies power for 4 coil packs each. Now that that the harnesses are unplugged, I don't know if I have it the same way I took it off or upside down.
I'm sure each coil pack has a certain sequence/order that they fire, so I'm sure that they need to be routed a specific way. How do I determine this?
I know that the harnesses are interchangeable from one side of the motor to the other, but which direction does it lay down? IE:
Let's say I was working on the passenger side. I layed out the harness, but instead of the 2 being on 2, 8 is on 2. Its flipped around. So how can I determine which way it goes.
By the way, I don't have any of those small sticker that tells which cylinder it will work for, so I need to know by wire color.
