Pics! Custom Over the Axle Duals - Flowmaster 40 series do fit afterall
#42
Sweet i bet it sound good with those mufflers! about time someone got a small enough muffler under the rear! Im going to do that but use a magnaflow bullet muffler one day!
Pant everything black and it will even look better and not show as much
#50
Hey fellas here's a link to mine, running the same mufflers only dumped if that helps you any.
h-pipe w/ dual 40 series race mufflers
![](http://thumbs.streetfire.net/77564754-5a4a-4148-bc05-9a320183205a.jpg)
#53
also, we need a damn clip of this other guy's setup already, lol!
#55
UPDATE: I still don't have sound clips.
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
I really want some though, so since it is finally not snowing in Ohio, I will work on it.
#58
I would lower it, but I think I want to run on ET streets around town instead. I'm hoping that it won't have much of a gap with ET streets and I won't have to lower it.
#59
I''m doing this.
Did you have to modify the upper panhard or bfh the floor board above?
And at the risk of repeating the last 50 posts... I need a sound clip... lol.
#60
I actually talked to Sam Strano on the phone about removing my upper panhard and he STRONGLY suggested to NOT do it.
He said if I needed proof, put the car on jackstands and push on the side of it. Then remove the upper panhard and do it again to notice the difference. If it wasn't that important, GM wouldn't have spent the time and money to put it on every single one of these cars.
