400fwhp without going into the motor ?
. Figure 25hp for headers - 350, then pulleys for about ~10? an electric water pump, and a lid. All that I would think would put you knockin at the door or VERY close to having it at the rear wheels. A mild cam would still be the easiest and most manageable thing. As someone else pointed out, depending on the cam you can even increase your mpg with it... if you can keep your foot out of it, but whats the fun in that?!Speaking of.. I need to get a lid for my car before I dyno again.. hehe.
As for the a4 vs m6.. I thought I remember reading somewhere the a4 was 15% and the m6 was 12% loss. Does anyone know for sure the drivetrain loss for each? Theres an app for my droid to give hp numbers depending on that and I'm just curious how close it is lol
I have the same app on my iphone and it is simply an inertia vs. weight calculation with alittle GPS thrown in for good measure,,, hell you can figure out how much horsepower your legs have if you wanna run a bit.
Vararam, ported TB, ported FAST 92, Kooks 1.75" LT's, catless mids, dual 3" cat back w/ X-pipe and 40-series Flowmasters, Monster level 6 clutch, lightweight flywheel (18lb steel), CF driveshaft, and a Tick Performance level 2 tranny with cryo and REM polish. Tuned by Matt @ SNL Performance.
Then they installed the cam for me, added a UDP, swapped to a 4" CAI/ 100mm MAF, and retuned for numbers in signature.
