what engine temps r u running?
Old Oct 12, 2007 | 08:32 PM
JHL88's Avatar
Default what engine temps r u running?
im asking this cause the past 2 days i think i might be running a little warmer than usual. 5 min into the ride the gauge spikes up to around 215 and neutralizes around 230-235 ish. i dont know if thats normal for LS1's but before that it would hold at 200-210. its weird cause the past couple days have been really cool outside and im a little skeptical. i was planning on doing BG coolant flush for it (even though its not that bad) but i have a feeling its the thermo
Old Oct 12, 2007 | 10:00 PM
King Nothing's Avatar
my 2000 stay at 209 once it's warmed up regardless of any temp outside. but i also did replace the water pump alittle over a year ago. do a flush and see what happens, you might need to replace your t-stat
Old Oct 12, 2007 | 11:26 PM
IZRED's Avatar
My temp. is dead at 180, whether it's in stop n go traffic or going 120 on the innerloop, also I live Louisiana, so the avg. temp. outside is 95+ degrees majority of the time.
Old Oct 14, 2007 | 11:50 AM
windshear's Avatar
If yours is a 98 then your temp gauge works. Might be time for a new thermostat. Any other year it just sits in the middle once the engine has warmed up. It only goes higher if it is overheating.
Old Oct 14, 2007 | 11:54 AM
LS1-NAVY's Avatar
i have a 2000 ss and mine stays around the 210 area
Old Oct 14, 2007 | 01:38 PM
JHL88's Avatar
yea thermo was my guess. if it was the water pump then it would be leaking, still could be a bad hose though we'll see
Old Oct 16, 2007 | 04:49 PM
DMONEY06's Avatar
mine runs really cool never hits 210 always 180 or lower
