Charging issue
Old Oct 13, 2007 | 08:20 PM
HAMRHEAD's Avatar
Default Charging issue
I have a drycell battery and can't seem to get it to stay charged. I put in a new alt and no luck. I checked my fuses and no luck. When I jump start the car it fires right up @ 13.37 volts but when I release the jumper cables it slowly falls back down. 11.27, 11.26, 11.24, etc. Until it gets around 9 something and the car cuts off. The battery holds the charge if I shut the car off as I have jumped it then let it sit for awhile and it still reads 11.67 volts. I'm at the end of my rope with this car
Old Oct 14, 2007 | 02:19 PM
quiet_storm98's Avatar
i had a charging issue a few weeks ago and it ended up being my positive battery cable, it is a pain to install though if you are using jackstands
Old Oct 14, 2007 | 02:28 PM
2001NBMZ28's Avatar
I'd bring the battery somewhere and have it load tested, if for no other reason just to eliminate it as the problem.
Old Oct 15, 2007 | 06:35 PM
HAMRHEAD's Avatar
Just tried 3 batteries and none of them would start it. It still has to be jumped even with a perfectly good battery.
