Materials for FAST 90/90
Old Oct 15, 2007 | 08:27 PM
tee-boy's Avatar
Default Materials for FAST 90/90
What else do I need to purchase to install the FAST 90/90 (which I just ordered). I also picked up the coolant pipe/plug kit for LS6/LSX intake manifold. What else do I need to purchase to do install b/w now and time it arrives?
Old Oct 15, 2007 | 09:13 PM
mzoomora's Avatar
14 Second Truck Club
You might need a new bellows if you cant stretch you old one over the new throttle body.
Old Oct 16, 2007 | 04:03 AM
Galen's Avatar
I would purchase some new intake gaskets. The Felpro ones ran me $20 at AutoZone...and I believe they are the same also marketed by FAST. My old ones were just too crushed to seal.
Old Oct 16, 2007 | 08:00 AM
wizkid's Avatar
Install Director
Not to get off topic, but do you need a tune for the car to run if you switch over to the Fast 90/90? You need a tune to get the most out of it, but I was curious if there were gains in it just from a direct swap.
Old Oct 20, 2007 | 10:27 PM
tee-boy's Avatar
Are the stock intake gaskets from Autozone or other parts store of your choice the same as the gaskets that FAST sells (looks like 8 large o rings)?
Old Oct 21, 2007 | 12:44 AM
98ws6firebird's Avatar
I just bought a fast90/90 combo and what I didn't get was the gasket that goes between the intake and the throttle body. You have to order that gasket separately. I couldn't believe it didn't come with.
Old Oct 21, 2007 | 12:57 AM
tee-boy's Avatar
Default dddd
You know I thought the same thing till I looked a little closer and the gasket was in the plastic bag. It was doubled up so it looked too small until I took it out. However, they don't include the intake gaskets.
tee-boy's Avatar
Default dd
Old Oct 21, 2007 | 05:20 AM
Galen's Avatar
I believe the FAST gaskets are the same. When I found out I needed some, I called Thunder Racing and they told me that they all seemed to be the same and worked just as well.
Galen
Old Oct 21, 2007 | 10:18 AM
MARKSZ71's Avatar
does the fast 90 kit not come with intake gaskets in the box,also i heard u had to silicone the intake so it want have any vacumn leaks
Old Oct 21, 2007 | 10:50 AM
litle88's Avatar
No they dont come with it! I have my intake painted and ready for install also!
Just waiting on my PTM 90mm TB from Texas speed for the install.
We will be needing intake bellows, I have been looking for some red ones, we will need the 4". I have found these places..
http://intakehoses.com/Merchant2/mer...ory_Code=CACH5
http://www.hightempsilicone.com/prod...e_Coupler.html
http://bakerprecision.com/silicone.htm
If anyone finds other places post them up!
Good luck guys!
Old Oct 22, 2007 | 10:00 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
You can heat up your stock bellow with a torch and it will fit over the throttle body
Old Oct 22, 2007 | 07:54 PM
litle88's Avatar
anyone else find anything we can use?
Old Oct 22, 2007 | 09:19 PM
RareBreed0295's Avatar
where did you get the coolant pipe/plug kit from?
Old Oct 22, 2007 | 10:03 PM
Z28/2002's Avatar
http://www.ws6project.com/user_stor/...3606fa68106e49
Old Oct 23, 2007 | 01:15 AM
Tram's Avatar
This may be an off the wall question, but I currently have the LS6 intake and am somewhat contemplating the FAST..
Can we use the stock fuel rail on it?
Old Oct 23, 2007 | 07:31 AM
Thanks Z28. ANd we can't use the stock fuel rails with the fast. You have to buy the fast fuel rails. You can get the fuel rails and installation kit for like $239 from speed inc
Old Oct 23, 2007 | 07:35 AM
LS1-NAVY's Avatar
^^ yup will also need the fuel rails and it looks good under the hood
Old Oct 23, 2007 | 08:59 AM
litle88's Avatar
You dont need to change the fuel rails for the Fast intake install!!
The stock rails bolt right up!!
Old Oct 23, 2007 | 09:25 AM
Tram's Avatar
Hmm
2 for need new rails..
1 for don't need new rails..
I love the internet..
For me, that would make this a deal breaker, if I have to shell out another 250 bucks for fuel rails..
