View Poll Results: Under the axel duals...ghetto?
Yes
48.39%
No
51.61%
Voters: 186. You may not vote on this poll
Duals under the axel...ghetto??
Old Nov 1, 2007 | 01:26 PM
  #81
2000taws6's Avatar
Sorry bud but I don't have a camaro. I think dumping the exhaust and having empty exhaust openings on the trans am's instead of tips is
Old Nov 1, 2007 | 01:58 PM
  #82
PAGregSS's Avatar
I have dumped TSP true duals right now and just got tips in preparation for running the pipes the rest of the way out the back. For you guys who say you can lift your car without removing the pipes, did you have the pipes run under the axle with the car on a two post and the rear at full extension? I'm undecided if I want to have the pipes installed with the car on a two post or a four post lift. They'd sit tighter to the car with the rear at ride height, but then again, not a whole lot of travel to the rear.
Old Nov 1, 2007 | 05:19 PM
  #83
98Camarod's Avatar
If you do it on a two post lift then you are going to rub on everything. The only way I can imagine this being done is on a drive on ramp or the rear on jack stands. You can put flanges on the exhaust so you can detach the exhaust from in front of the axle back so you can use a two post lift.
Old Nov 1, 2007 | 06:40 PM
  #84
chromeplated500's Avatar
I think it looks good... .reminds me of the 70's corvettes....
Old Nov 1, 2007 | 06:50 PM
  #85
LSGunZ28's Avatar
I dont care how it looks.
its too damn low. Unless its a DRAG ONLY car. Id say. NO!
Old Nov 1, 2007 | 06:51 PM
  #86
BayAreaSS's Avatar
I like it. Im thinking about having my duals ran just like that. It is almost impossible to find someone around here that can go over the axle.
Old Nov 1, 2007 | 08:33 PM
  #87
speed_demon24's Avatar
Um how is it too low when it's not any lower than any dumped exhaust setup?
Old Nov 1, 2007 | 09:58 PM
  #88
2000taws6's Avatar
like speed demon24 said how is it too low? look at the pipes they dont turn down or go any lower than the lowest spot in the x-pipe. I don't get some of you
Old Nov 1, 2007 | 10:01 PM
  #89
98mysticZ's Avatar
if it was done right then it would look good... but i wouldnt go that route mine are dumped before the axle
Old Nov 1, 2007 | 10:06 PM
  #90
venom ws7's Avatar
Awesome looking setup man.
And NO it not Ghetto at all.
Old Nov 1, 2007 | 10:32 PM
  #91
LSGunZ28's Avatar
Its not?!
Old Nov 2, 2007 | 12:13 AM
  #92
Revelation Z28's Avatar
also, you wont hit speed bumps with the pipes since speed bumps stay below the tires.
i love the look of under the axle duals.
2000taws6, the best part of how your's looks is both pipes are symmetrical. both at the same height.
Old Nov 2, 2007 | 12:47 AM
  #93
2000taws6's Avatar
Thanks
Old Nov 2, 2007 | 01:22 AM
  #94
headed-ws6's Avatar
I Have true duals ran over the axel and not with a panhard relocation. It goes from 3 inch down to 2 and a half. payed 550 for it. Im happy with it. Thats what I wanted so I payed for it. It doesnt hit the rearend and sounds awesome. to each his own.
Old Nov 2, 2007 | 01:35 AM
  #95
Its not?!
Ok since you're so smart and have experience with running them out the back explain how it is lower when it is run out under the axle vs dumped.
Here's a pic of mine.
Old Nov 2, 2007 | 11:15 AM
  #96
andrew69_04's Avatar
IMO people run them under the axle cuz they dont want to spend the money to have them done right. if you like it under then run it under. i would never do it becuase it seems like a hassel, take your pipes off to lift your car. IDK its your car so do whatever you want. I dont see why people put a ton of money into there cars then cut a corner here.
Old Nov 2, 2007 | 11:54 AM
  #97
99Hawk262's Avatar
^^^What's wrong about under the axle and right about over the axle? It's not cutting corners either. It's an option. It works well either way.
Old Nov 2, 2007 | 01:41 PM
  #98
How is it cutting a corner. And I DON'T HAVE TO TAKE OFF MY EXHAUST TO LET THE AXLE HANG. I HAVE ALSO NEVER SCRAPED THE UNDER THE AXLE PIPES.
I've scraped my collectors many times, but never the under the axle pipes and my car is lowered 1.2-1.3" with 3" duals.
I LOVE how people with absolutly no experience with this know all of the answers.
Old Nov 2, 2007 | 04:10 PM
  #99
ws.6kid's Avatar
Over the axle just looks way cleaner. I don't understand why you would want to go under??? there are no advantages except maybe saving a hundred dollars or so. Just but the BMR relocation kit and go up to 3.5" pipes over the axle!!
I wouldn't trust under the axle especially on drag radials/slicks when your car squats...
Over the axle for the win.... It been done this way since the firebird and camaro first came out in 67...
Old Nov 2, 2007 | 04:12 PM
  #100
What's the advantage with going over the axle... besides spending a few hundred $$ more?
