Watershielding 02 extensions?
Old Oct 30, 2007 | 03:24 PM
Halloran's Avatar
Default Watershielding 02 extensions?
Well, I recently put in some Hedman LTs in my car and had to extend the 02 sensor lines and get it tuned. Yesterday we had a downpoor of rain. While driving the car would just randomly bog and have almost no power, then every once in a while it would just kick in and run as normal. Then it threw a P0300 random misfire code. I took it to Kragen and cleared it. It has only done it a few times today but has been running much better. I'm sure it has to do with my heat wrapping job I did on the extended 02s. Is there a good product to shield extended 02s? I just hate having the car run like crap then have your neck jerk back when it decides to run normal. Whiplash is not my friend.
Thanks!
Old Oct 30, 2007 | 03:33 PM
WS6NIGHTMARE's Avatar
Get used to it, its just one of those things some of us battle with, like me. I avoid puddles at almost all costs when I drive my car. It seemed I killed one almost once a month in the rainy season. Albeit they were under warranty, it was still annoying. Last time it happened, I just cleared the code when it would pop up and I would drive the car anyway, after one or two times of that, it never came back. So maybe it just takes a little driving to get it all nice and dry again, then all is well, I dunno.
Old Oct 31, 2007 | 12:35 PM
radkon's Avatar
Did you use premade extensions or did you solder your own? I've never had a problem with my Casper's extensions. They use weather packs like the OEMs.
