New true duals
For those that are curious, the new found lope belongs to my new ARE 382 Solid Roller instead of the 224 that I had in the prior videos.Videos, right click and "save as". I'll convert them to WMV next weekend to make them a bit smaller in size.
Here's the vid at idle
Here's the vid at rev
Here's a pic:
As far as the turn downs, since it all flows out the *** end I really don't give a crap if they are crush bent or not. I guess you'd pay $250 for the Dr Gas X pipe and $50 for some nice mandrel bent turn downs. I've got other things to spend that money on at the moment, so I opted for the cheap and just as effective method.
. Are those muflers a straight-through design? I might also so want exhaust run over the axle because the dumped exhaust is starting to annoy me. Just to loud! But maybe using some "real" mufflers instead of the Bullets will quiet it down some.
Thanks
A buddy of mine owns an exhuast shop up in Big Rapids. The majority of the cost was the Borla's, at $150 each. Then I just paid for the material and a little labor. I have to support his racing habit, all 7 seconds of it. The Borla's on mine are the 12" long 3" diameter style.
It rumbles pretty hard with the new setup, but just as comparable as the Corsa. I don't think it's any quieter or louder in that respect. So far the turn downs kick up a little extra dust, but that doesn't bother me. We made the turn downs with the pipe bender just because we wanted to figure out if that's the way we were going to keep them. If I change my mind I can simply unbolt the clamp and slide that one out and replace it with a different style. The rear hanger is actually welded to the clamp so I can easily move things around.
I'm actually going to fabricate a new torque arm bracket in place of the Spohn bracket to get it out of the way. If we buy enough material I can possibly fabricate one for you as well. I'm just thinking some chromoly tubing that curves into the tunnel should give you clearance enough for the x-pipe. I'm going to reuse some of the parts off from my Spohn mount to do it.
As far as the holes in the back go, I figure it just gives you a better view of what just kicked your ***. So that doesn't bother me at all. Ground clearance wise, it's not rubbed on the great roads we have in Michigan. And at the strip with the rake of the 28 rear / 26 fronts they actually raise up a little more. No issues there. Now, if we have to park at the lot we had for Woodward last year, I'll be going elsewhere because four wheeling will not be possible.
