Seat of the Pants Bolt Ons?
basically i say stall
Go with a Yank ss3600 or a pt4000 .
Pick your stall to your gears you plan to run .
Me with 4.11's ... Id go pt4400 . It would hit hard as fu$% off the line . These new age converters lock up , no reson not to go big .
I don't understand why people are saying "stall." By the time they get in installed and buy a tranny cooler, you're going to be in the hole over $1,000, especially if you decide to add a shift kit and a tune, which is ideal. Even if you buy some second rate used converter, you should ship it away to get refurbished, then you need the tranny cooler, shift kit and install cost tacked on to that, too. People that recommend stalls for people's first mod and for a budget mod are
With that said.. Like other mentioned a Converter something in the 3200 range up to 4000 depending on how saucy you feel is the best bet. I took .6 of my 1/4 mile with 2.73's just putting a stall with sticky tires on my car.
As for $500 no way your going to do a stall for that. Since headers and intake are done, Id say save it.
Its cheaper to do it all at once, rather than putting a part on here and there.
