Hooking up gauges, what size adapter
Old Nov 22, 2007 | 02:54 AM
playtoy's Avatar
Default Hooking up gauges, what size adapter
Does anyone know what size adapter I need to hook up my engine temp sensor to a set of 5.3 heads? Is it a 10mm or 12mm to 1/8" npt?
Old Nov 22, 2007 | 05:39 AM
LS1MCSS's Avatar
I "think" it's 12MM, but don't bet the farm on it. I could be wrong.
Old Nov 22, 2007 | 07:44 AM
LS1 SPEED's Avatar
We always drill and tap the top of the water pump. The sender can then be screwed directly in and it will be more accurate.
Old Nov 22, 2007 | 11:10 AM
bczee's Avatar
It is 12mm.. I drilled my out head to 1/4"npt. But some of the manufactors are now making adapters for there gauge senders.
