LS1 grenade
Old Dec 1, 2007 | 12:45 PM
1320 killer's Avatar
sorry to hear that. I know the feeling it sucks. but on the other hand it's a pretty good reason to forge it and more power.
Old Dec 1, 2007 | 02:22 PM
Tainted's Avatar
lmao with 3 blocks maybe we can make an 8.4L Viper V10 LS10
Seriously, I dunno why these motors gernade, mine was running STRONG no skips no misses with 94k on the clock, all maintence, no nitrous ever, I dunno what happened with mine even after we tore it apart. both rods broke in the center is all we could ever figure out.
When you get yours tore down please, let me know what happened.
Old Dec 1, 2007 | 03:10 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
DAMN....just saw your thread the other day-----sorry man...
Old Dec 1, 2007 | 03:25 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
To the OP did you happen to notice if you lost oil pressure?
Originally Posted by BLK02TA
So whats up with the other two? Grenaded on startup?
Tainted's and mine both went on startup.
Old Dec 1, 2007 | 05:18 PM
ae13291's Avatar
is this problem only on the 97 and 98 ls1?
Old Dec 1, 2007 | 11:45 PM
The Trans Am Kid's Avatar
Sorry, but what is Granading?
Old Dec 2, 2007 | 11:04 AM
danielgoforth's Avatar
Pretty much means your motor blew up
I didn't notice a drop in oil pressure prior to the problem, the whole thing just went at once. I would assume it dropped after the motor punched a baseball sized hole in the pan tho
Ill probably tear it down over Christmas break and see whats going on. Hopefully ill be able to buy a new block and re-use most of the parts. At least then ill know if something is wrong or worn out before i drive it
Damn used motors
Old Dec 2, 2007 | 01:08 PM
OWN3D BY MY PROF!
Might have been an oil pump on it's way out if you were noticing a drop in oil pressure. Did it leak any oil? Maybe it was just low on oil?
Old Dec 2, 2007 | 01:13 PM
Speed Kills's Avatar
I know the feeling. '98 block, 70K miles, all maintenance, and after my cam swap, it lasted 100 miles of easy driving with perfect oil pressure before mine let god.
Start saving now.
Old Dec 2, 2007 | 01:16 PM
Tainted's Avatar
mine was a 1999 so I doubt its year specific since the 99 didnt have the 98 oiling thing, something about a restrictor plug or somethin like that.
Old Dec 2, 2007 | 03:05 PM
King Nothing's Avatar
Originally Posted by danielgoforth
Damn used motors
i would never have done that . . . but then again i've seen some new motor blow up good luck on the whole situation though
Originally Posted by Speed Kills
I know the feeling. '98 block, 70K miles, all maintenance, and after my cam swap, it lasted 100 miles of easy driving with perfect oil pressure before mine let go.
did you swap out your oil pump for a better one and change the gaskets?
Old Dec 2, 2007 | 04:07 PM
  #32
OWN3D BY MY PROF!
Mine was a 98. I don't think it's a year specific thing. It just looks like that because of the frequency of 98s blowing up. I think it's just because they are getting old and have a lot of miles.
Old Dec 2, 2007 | 04:42 PM
  #33
merriman44's Avatar
Couldn't help but jump in on this thread as I kept thinking about a marine starting up the engine, counting to three then sticking it in drive and leaping out. BOOM... sorry bout your luck though.
Anywho, LS2 block is cheaper....
Let the snow ball effect begin! My 99 engine had 4 cracked sleeves. I was just gonna rebuild another stock one...
Now I'm building a 402 and it will cost just a little more than a 346 hehehe...
Old Dec 3, 2007 | 02:08 PM
  #34
OWN3D BY MY PROF!
I wouldn't say it would just cost a little more. All the stuff I've bought for my backup / possible camaro engine has been super budget.
$300 shipped BNIB Diamond pistons
$270 shipped Scat H beam rods
$0 Have a stock crank
$280 shipped CNC Ported 806 castings set up for solid roller
Things I need
Block $350
Balancing / Machining (same for any engine)
Rings (same for any engine)
Bearings (same for any engine)
Gaskets (same for any engine)
The only additional costs involved in mine are the solid roller pieces. I'll probably still come out under what your 402 setup costs by a considerable margin. I'm not knocking you, just don't make generalizations. I agree with you to an extent though. You can do budget large displacement builds .....
