loss of power after header install.........
clear the computer and allow the car to re-learn the a/f curve after the headers
sometimes the car will feel slower at lower speeds, but the headers should unleash good power up top. it may be all in your head.
if the ypipe is hitting, you could be getting false knock and the computer is pulling timing...which will REALLY hurt power.
what you needed to do was install poly motor mounts when the manifolds were off, before putting the headers on.
Thunder racing sells a mufflex piece that keeps your ypipe from banging. or you could have a shop clearance the pipe a little. heat up the spot and pound it in for some more clearance. it won't be enough to affect power, but 1/2" of denting can make all the difference on clearance with the frame.
something like this, on my old flowtech ypipe:
either you have a leak, or you're A/F was out of wack to begin with and the headers messed it up more.
do you have track times to prove you lost power? dyno numbers?
very possible the callibration on your SOTP meter are off too.
Might not be a loss in power, it is probably just a shift in the torque curve. Your peak TQ numbers might have moved into the higher RPM's, much as they do when you open a cut-out.
But really, you probably did something wrong.
FYI headers you will feel more at WOT than when just goin 1/2 throttle on it to speed up. All though I can honestly say after my header install I felt it all the time.
Something is wrong with your car. Stop driving it, take it to a shop.
I dynoed my car after headers and true duals and found I went from 306HP to 344HP and from 325ft/lb to 352ft/lb.
After the tune I went up to 349HP and 359ft/lb.
The only reason the "down low" felt weaker is because it didn't change much if at all but the upper goes up. It's one of those perspective things. The torque curve jumps up quite a bit and will gain a true peak. Before my headers, I had a dead flat torque curve ~15ft/lb difference between 4k rpm and 2500rpm... After headers, I had a new torque spike of 359ft/lb from 4000-5000rpm. It became my sweet spot (below and above was in the 340ft/lb range, but you could FEEL that 4k spike...
If you have a 6 speed think of it this way, if you lost power down low, you'd have a hard time accelerating in 6th under 2krpm, or at least it'd be significant enough to make it lug around. In fact, I found that I could accelerate a bit better in 6th under 2krpm (if you can still overtake a car at highway speeds using cruise control in 6th then you can be sure you didn't lose any power).
